Axle flip kit?
Axle flip kit?
Hi all,
I am about to fit my axle flip kit but I want to make sure that I’m fully prepared. Are all of the bolts reusable or will they need replacing?
If they do need replacing do you all use VW stretch bolts or just replace for normal bolt so they are reusable in the future?
- Liam
Re: Axle flip kit?
you replace almost all the bolts with the ones supplied in the kit
Build thread here
Build thread here
Re: Axle flip kit?
massive facepalm moment, it’s been a while since I looked in the box!
Thanks for the reply!
- Liam
Re: Axle flip kit?
no worries
Build thread here
Build thread here
- JAZ8140
Re: Axle flip kit?
what kit have you got as I want to do this to mine
Re: Axle flip kit?
I have thethe Stance+ kit.
- JAZ8140
Re: Axle flip kit?
cheers mate
- Liam
Re: Axle flip kit?
buy the best kit you can afford as otherwise you will be buying again a few months down the line
Build thread here
Build thread here
- hef355
Re: Axle flip kit?
Agree with Liam here, Darkside kits ate really well engineered in my humble opinion, used Eibach and KW in the past and darkside for me are superior
- JAZ8140
Re: Axle flip kit?
I don't mind paying good money for quality but cheap by twice , do you have a link to the darkside one please sorry to be a pain
- hef355
Re: Axle flip kit?
No trouble at all here you go, I would go gor the super low option as it has an off set locator which is off centre. This will ensure the rear wheel always remains central in the arch. Message me direct if you want my number, happy to help fellaJAZ8140 wrote:I don't mind paying good money for quality but cheap by twice , do you have a link to the darkside one please sorry to be a pain
https://www.darksidedevelopments.co.uk/ ... sters.html
- sheepy92
Re: Axle flip kit?
what is the best kit bud regardsLiam wrote:buy the best kit you can afford as otherwise you will be buying again a few months down the line
- hef355
Re: Axle flip kit?
For the sane ish kind of money, I wouldnt go VMAXX personally as i inow a few friends who have had issues. I run KW front and darkside super low rear with shortened gaz shocks. I run 20” and use it daily and its brilliant! KW are big money but ive also used STX that are made by KW and are brilliant for front! You could sell the lowering kit and dampers and then buy a darkside kit and Gaz which in my opinion would be a great set up for not massive money
- JAZ8140
Re: Axle flip kit?
cheers buddy i can't pm yet so as soon as they grant me access to the over 30 posts section I will mate
Re: Axle flip kit?
do you have to change rear shocks when you flip the axle ?
