Hi, I crashed my van and rebuilt it, I replaced the headlights with aftermarket ones which have 2 separate bulbs one low beam and one high beam where the original lights had one bulb , the problem is I’ve took it for an mot and it’s failed on the headlights because when you put them onto high beam low beam goes off and apparently it has to stay on, does anyone know how I can do this without having to buy more headlights ?
Aftermarket headlight help
Re: Aftermarket headlight help
If this is a 2010-2015 shape caddy, there is a coding change to be made when swapping H4 bulb headlight for individual bulbs for high and low beam.
Have a look in the electrical section, it is in there.
Brilliant I’ll have a look thank you
I tried looking and it says I don’t have permission to view the content
- dan@biali
Have you asked in the appropriate thread for your account to be upgraded? http://caddy2k.com/forum/viewtopic.php?f=1&t=31039
No never knew i had to, I will though thank you
How long does it normally take to get permission ?
Vans got to be back in for retest before the end of tomorrow
- dan@biali
As that thread states, anywhere up to 7 days. You could have asked to be upgraded when you had 6 or more posts.
Ah ok thank you
I will just have to book it into somewhere tomorrow then
I managed to sort it , got the info off another forum in the end , thanks to all that helped
