Gas van build
- Tommyd1992
Gas van build
Got myself an ex BG gas van last summer and after reading so many build threads I thought I’d start my own. It may not be as fast paced as some of the others! This was the van when I purchased her.
- Tommyd1992
Re: Gas van build
Started off by adding the sun strip
- Tommyd1992
Re: Gas van build
Also replaced the radio with the rcd330. Was really unsure of this radio as it was so cheap but after reading as many posts on the forum as I could find I decided to go for it.
When removing the parrot kit that was installed by the previous owner I found this glorious hole in my dash.
- Tommyd1992
Re: Gas van build
Next up was pressed number plates. Thought these made a huge difference
- Tommyd1992
Re: Gas van build
Treated myself at Christmas to a set of 18’s
- Tommyd1992
Re: Gas van build
A week later I took her in for lowering with H&R front spring and darkside rear kit. Sits much better.
The next day I took her in for a remap which I was told took her up to 152BHP which I can fully believe. The difference is brilliant... the fuel consumption is not. Haven’t decided if it’s the map itself or if it’s me being a lot more throttle happy now that it responds.
- Sean1066
Re: Gas van build
That’s just how mine looked when I picked mine up 15 months ago.
I’ve had fun doing mods to and still not finished
- Tommyd1992
Re: Gas van build
Sean I have followed your build for some time. It looks great. You are a few steps ahead of me with your build. I have done a bit to my van and will update this thread as I can.... a bit new to this still
- Tommyd1992
Re: Gas van build
Forgot to mention the heko wind deflectors.
- Sean1066
Re: Gas van build
Thanks Tommy.
Yours is looking a good build
- Tommyd1992
Re: Gas van build
Finally fixed the largest cup holders ever installed with a brilliant 3D printed insert.
May have to colour match it in time
- Tommyd1992
Re: Gas van build
Also fitted my led DRL’s and fitted a HID kit.
The blue headlight is a lot more white in person
- Tommyd1992
Re: Gas van build
Upgraded the indicator repeaters with these LED’s. Had to fit resistors to stop the fast flash bulb warning when indicating.
- Tommyd1992
Re: Gas van build
Upgraded the interior light unit to a Passat unit and fitted blue LED’s
- Tommyd1992
Re: Gas van build
Last of the goodies from the weekend was the auto headlight switch. It flashes the headlights four times when I turn ignition on and then works flawlessly on auto but does not flash if I just leave it set to the headlight position. Not sure I have the right switch.
