mikenorman
Post by mikenorman »
Awesome work James
Lewis1983
Post by Lewis1983 »
Lewis1983 wrote:Just stripped my caddy lights apart to paint them black
Heated gun worked a treat they came apart In no time at all.
Primer and then satin black.
Finished in satin black ImageImageImage
brooneye
Post by brooneye »
@james400 they look great, did you have much trouble putting the door cards back together? I found it a complete nightmare
james400
Post by james400 »
No pretty straightforward it was just working out how best to feed the light in so just drilled two small holes behind the trim and threaded it through more fiddly than anything tho
Sportvan
Post by Sportvan »
It obviously doesn’t want to work today, temp gauge shot up into the red, can’t see any signs of over heating so possibly a sensor. Don’t want to risk it, so waiting for VW Assist above Abbotsbury Image
Primal730
Post by Primal730 »
At least you’ve got a nice view...!!
Hope you get sorted pal
11 plate caddy
Lowered
Porsche 18’s
Golf gti seats
More to come
r1lea
Post by r1lea »
Got a leather gear gaitor with white stitch to match my seats and armrest Image
DaveN
Post by DaveN »
Lewis1983 wrote:Finished in satin black ImageImage
Post a pic when they’re back in the van. They look great.
Sportvan
Post by Sportvan »
Primal730 wrote:At least you’ve got a nice view...!!
Cheers mate it’s at the dealer, temp gauge didn’t move after VW assist had been out. Got a standard high line with 150 DSG. The standard ride height and springs are vastly better then the factory lowering option. This van handles loads better then mine. So I think I’m going to raise my van back up on standard springs!
MattMan
Post by MattMan »
sheepy92 wrote: Wed Feb 06, 2019 5:41 pm Carried on with lowering/poly bushing up sitting nice on the rear now note for future reference for people shackle bushes can be a nightmare to remove specially back box sideImageImage
What did you use to remove the bushings out the chassis? These are the last two on my van i need to replace, was thinking about burning them out as i haven't got any sockets big enough to push the old ones out into. Cheers
james400
Post by james400 »
I burnt mine out much faster lol
MattMan
Post by MattMan »
Did you ruin any of the underseal when burning them out? Might give it a go on Saturday
Sent from my ONEPLUS A6013 using Tapatalk
james400
Post by james400 »
No I did mine with the gas axe so it melted when it caught fire I just blew it out so no damage done to the under seal
MattMan
Post by MattMan »
Ah sound. I've only got a blow torch but should do the trick. Might buy some underseal just incase
Giddy
Post by Giddy »
Piece of pipe 45mm inner diameter, threaded rod, some nuts and washers, that's what I've used to remove mineImage
Caddy 4, Highline, 1.4 TSI
Instagram: @giddywagen
Build thread >>> here <<<
