Rear seat belts
Rear seat belts
I could really do with help on installing my rear seat belts, anyone have some clear pictures of them installed, mine are from a caddy life, also what spreader plates did you use, I would search but I don’t have enough post, hope some one can help
- Jonesandrew6
Re: Rear seat belts
Where abouts in the rear as normally just go by the sliding door i think but i had mine installed in the rear tail light pillars had to have a threaded nut welded to a plate and welded and rivoted into the pillar in two places on mine will post some pics of where mime is installed
Re: Rear seat belts
Just behind the sliding door, just want to see if I’m looking at the right spot, especially the lower belt.
Re: Rear seat belts
I thought these fixings would be in all maxis?
Re: Rear seat belts
Mines just a swb, I’m fitting the caddy life seats, I can’t believe the seat belt anchor points are not installed from factory on all caddy
Re: Rear seat belts
Hi
Does anyone know the distance that the middle row seat belt anchors should be fitted?
- BradleyB
Re: Rear seat belts
I’ve now sold the caddy I installed the rear seats into so I can’t take pics for u but
I purchased all my seats and hardware from Sirus
You need to drill into the metal partition
I then used masking tape to hang the spreader plate down behind whilst threading seat belt bolt through so you don’t keep dropping it lol
It’s a bit of a fiddle but if I managed any one can do it
Re: Rear seat belts
Thanks, I’ve now in stalled the seats and seat belts
Re: Rear seat belts
Hi
anyone know what brackets go under the floor(under the tank to secure the rear brackets?
