Brooneye's build
Dan4da
Re: Brooneye's build
Post by Dan4da »
Brooneye, what did you do for Sun visors? Did you paint them or retrim?
brooneye
Post by brooneye »
@Dan4da I used 2 tins of black flexible vinyl paint from Halfords. I’ve used this on numerous sets and find it a much better finish for the visors and for the rest of the upper plastics it was gloss black paint
Dan4da
Post by Dan4da »
Thanks dude
brooneye
Post by brooneye »
No bother, don’t forget to do light coats and build it up slowly
brooneye
Post by brooneye »
Air box out and ready for the new climatronic one
Still not found that quid? :P
brooneye
Post by brooneye »
Not yet Doc
But to be honest at one point I started to doubt why I put myself through this
brooneye
Post by brooneye »
Bit of an update on the head unit, pioneer more or less said tough it’s now out of warranty. But Halfords have agreed to replace it with a pioneer sphda130dab. This is a newer version and also has the built in dab.
Just got to get all the dash back in before I can test it
brooneye
Post by brooneye »
Managed to get the thick end of the engine pipes ran and hopefully tomorrow I’ll get the new radiator on
Post by Stedlocks »
that lot looks like a snakes wedding! blimey, fair play fella......I wouldn't know where to start!
brooneye
Post by brooneye »
Cheers, it’s been daunting at times but had the help of a friend.
Although I’ve spent the last couple of hours trying to get the pipe from the compressor to the condenser and the thinner pipe from the condenser to the heater box to fit correctly and it is starting to make me angrier as they just won’t go
Calamity Kev
Post by Calamity Kev »
brooneye wrote: Tue Mar 05, 2019 5:04 pm Air box out and ready for the new climatronic one
That looks terrifying :shock:
Good luck!
Ride Bikes Drink Beer
brooneye
Post by brooneye »
All week I’ve thought I’m mad when looking at the state of it.
Heading in to the last couple of bits now but I’ve had to walk away from it today as the last two pipes are not sitting correctly and for the life of me I can’t figure them out
brooneye
Post by brooneye »
Don’t if any one can help, but this is the problem I’m having
The kink in the pipe
Then how to line this one
Any help or ideas would greatly be appreciated
Have you got more of a overview of your pipe arrangement?
Top top (thick) from the bulkhead should go to the inner most connection on the pump.
Outer pump connection (nearest to the pulley) goes to the condenser.
Bottom pipe (thin) from the bulkhead goes to the condenser.
This is from memory, I've not looked at any diagrams.
