under seat draws?
daniel010daniel
under seat draws?
Post by daniel010daniel »
hello!
i know in the touran u get under seat draws which look quite handy,does any one know if there any thing for caddy's which will fill under stander caddy seats. 2007 caddy
cheers
horace01
Re: under seat draws?
Post by horace01 »
Standard seats in Australia come with draws. I'll see if I can get a part number for you.
Bigharty
Post by Bigharty »
I have a set of draws from my 2013 caddy seat if that's any help
BIGHARTYBIGHARTY
daniel010daniel
my seat are the same as the pic horace01 has put up are the the same on the 2013 if so i would be interested
part no. would be gratefully received bud
NornIron
Post by NornIron »
Bigharty... if daniel010daniel isn't interested, I certainly am!
Have posted a couple of "Wanted" ads, without any joy!
Ich habe kein Geld!
horace01
Post by horace01 »
My comment above is not quite correct. The items I showed are actually stowage compartments. You can actually get stowage draws too. The difference is self explanatory in that the draws slide out and the compartments do not.
As for part numbers it depends if you want draws or compartments. You will also need the appropriate fittings too.
Here is a good place to start....follow the links to VW Caddy 2007 body section and look at seats. Sorry I tried to post the actual link but it's not worked.
http://www.partscats.info
Audisport
Post by Audisport »
I've got a drivers side storage drawer out of a 2011 maxi life, only removed as I have seat swivels and its incompatible with them. Looks totally different to those posed above though, I'll get a pic and part number tonight.
skinnyd
Post by skinnyd »
Any update on this?
Need a part number for underseat drawers for a caddy4 maxi.
My spec sheet says I have “seat draw preparation” so I’m assuming it’s a simple plug and play solution?
Which seats do you have in your Caddy4?
There are some that come on the much sought after Touran bases which will accept the Touran base storage pocket.
The caddy standard seats can accept a pocket mounted on the seat rather than the base.
BradleyB
Post by BradleyB »
@doc
Sorry just to confirm
If my MK4 highline caddy come with under seat storage drawers
Does this mean I already have touran seat bases
Or would I still need to change bases in order to fit golf mk7 seats
skinnyd
Post by skinnyd »
@Doc
Here are my seats.
Side view of driver
Under driver seat
Passenger seat looks different underneath
skinnyd
Post by skinnyd »
Any feedback @Doc?
r1lea
under seat draws?
Post by r1lea »
No your seats are not on touran bases
You don’t have storage either
Yes you would need them to install mk7 golf seats
skinnyd
Post by skinnyd »
Yes no drawer now but the spec sheet specified a “preparation” so not sure if it just needs to add something easily
r1lea
Post by r1lea »
Probably just means you have the holes for the screws etc
Passenger side is correct
Drivers side has the front cover panel missing
