2007 Vw caddy Egr delete?
Glen G
Post by Glen G »
Hey lads general question..I a 07 caddy 1.9 TDI I want to delete the Egr valve. Just wanted some feedback is it worth doing.. Is there much work involved in doing it?
I see darkside have one on there website...
Thinking of deleting EGR getting a full stainless exhaust system and a decent map
Re: 2007 Vw caddy Egr delete?
EGR delete is kinda pointless on the BLS as it doesn't really cause that much restriction. A much cheaper option is to buy a blanking kit and have the EGR removed from the ECU map.
Glen G
Post by Glen G »
Yeah a friend of mine was recommending me to blank it off put exhaust system delete the cat etc.. And a decent map.. And should a make a good 40-50bhp extra what's your opinion on that mate?
It'll make +50bhp with a good map without doing anything like that.
A simple EGR blank and leave the cat where it is to avoid smoking and MOT problems would be my recommendation.
I am aware EGR blanking is a MOT failure but you can fit blanks in place of the factory gaskets and leave the whole system in place. That way it is undetectable from a visual inspection.
Glen G
Post by Glen G »
Il take your advice Doc!! Il start with blacking it off and a good map... Where would you recommend to get the blacking cap
From?
You can buy them off eBay, just don't go for anything very think if you're gonna leave your cooler attached, 1.5-2.0mm will be think enough. Once it's mapped out it'll not matter anyway.
Glen G
Post by Glen G »
Perfect 👌 thanks mate
