My caddy build and face lift
KenTDI140
Re: My caddy build and face lift
Post by KenTDI140 »
I have found a way to make it all work but it means stripping the lights down. Doing away with the led set up and building my own led lights and using traditional wiring methods. One light is finished and works fine but I just have not had time to do the other one yet.
anoneamus
Post by anoneamus »
Pirelli901R wrote: Thu Mar 21, 2019 7:46 pm I'm trying the same thing, I have the same problem, had new bcm 5K0937087 but still no high beam and leds.
If you have a BCM you can do the proper retrofit. KenTDI140 had to do major workarounds as he is using CECM which doesn't have support for ALS. Your description implies you have either not fitted ALS, or it is not wired/coded correctly. Here is a guide for the retrofit:
https://caddy2k.com/forum/viewtopic.php?f=22&t=25064
KenTDI140
Post by KenTDI140 »
The retro fit was not possible on my van as it’s an 07. I would have had to totally fit an 11 plate on loom which is more than I was prepared to do.
I have not fitted als
Pirelli901R
Post by Pirelli901R »
anoneamus wrote: Fri Mar 22, 2019 10:23 am If you have a BCM you can do the proper retrofit. KenTDI140 had to do major workarounds as he is using CECM which doesn't have support for ALS. Your description implies you have either not fitted ALS, or it is not wired/coded correctly. Here is a guide for the retrofit:
I can't open topic because I still don't have permission. My Caddy i 2011, I wonder is it big diference in 087A wich I have and 087AC wich I found someone in this forum had proper retrofit?
anoneamus
Post by anoneamus »
Pirelli901R wrote: Fri Mar 22, 2019 9:54 pm I can't open topic because I still don't have permission. My Caddy i 2011, I wonder is it big diference in 087A wich I have and 087AC wich I found someone in this forum had proper retrofit?
Contribute. Make a topic about your van. This is a give and take forum, so if you want to take you must give. In any case, as long as your BCM is 086 or later (I really don't think it makes a difference which letters follow), it has the necessary support for BiXenon. If your van is 2011 you must have replaced BCM, as 087 was only factory fitted after 2014 AFAIK.
Azz03
Post by Azz03 »
Wow is all I can say ken you’ve got an incredible amount of patience and skill love the motivation you have even after trashing the front end you’ve bounced back like it’s nothing top notch mate just a quick one you’ve clearly got a lot of knowledge on engines and how they work lol I’m wondering do you know much about the engine conversions?
Thanks in advance.
KenTDI140
Post by KenTDI140 »
The conversion is the easy bit it’s getting the ecu to work that’s the hard bit and wiring changes.
Although mine is heavily modified it’s still essentially the std 1900 engine so I’m still on my original ecu.
Azz03
Post by Azz03 »
My friend/mechanic was part way through it but sadly passed away so I’m left with an unfinished engine. Was just wondering if I could pm you as I’m stuck with a few things. Thanks for the reply.
KenTDI140
Post by KenTDI140 »
I’ll try to help if I can
Sean1066
Post by Sean1066 »
Hi ken
How did you get your mk7 Golf steering wheel to work?
As I have one but can’t get it to work?
Caddy maxi 3.2 VR6 EX BG
My build thread
KenTDI140
Post by KenTDI140 »
If I remember right I moved one wire so that the horn worked the lights don’t work but all the main controls do
scatman75
Post by scatman75 »
i will be using this built to do my own facelift...
KenTDI140
Post by KenTDI140 »
I haven’t done any more to the exterior and I just haven’t had time to get the other headlight modified yet as I have had so many jobs to do on the house and new garage.
I did spend more time fine tuning my tune and I’m now pushing close to 300 bhp.
Mklogz
Post by Mklogz »
Wow that’s fantastic
Caddy2899
Post by Caddy2899 »
Very nice job, it looks well. A credit to you
