new caddy with mods planned
- lord-dudester
Re: new caddy with mods planned
Splitters turned up from TPS today. Gonna get it on tonight. Looks like it needs a few bolts here there to hold it all together too so I’ll get up Halfords tomorrow for some fixings
- Caddyluv
Why not get the correct ones from TPS?
- lord-dudester
- Caddyluv
Fair enough.
- lord-dudester
Adding to that. I’m at a dead end as I can’t find a diagram for the Clubsport front end with the part numbers on line. Assume it’s only on the latest etka and not the versions that are accessible via the web
Can any one help pls?
Which part numbers do you need?
- lord-dudester
Thanks doc
Just wanna check the prices for the fixings. Also want to see the layout of the vents/ducts behind the front face of the bumper and see how many parts are involved. I’ve a feeling when it’s on it may sit a few inches away from the van and look a bit hollow from the front. So I was going to see if the internal ducts would need purchasing to make it look right by packing it out a bit - if you get what I mean
- lord-dudester
Looking for the numbers for these ducts that clip to the reverse of this triangle bit. I wanna see how big they are and if they’ll fit when it’s on. It’ll definitely look better with them in
- Gresley
Think it's these:
https://www.ecstuning.com/b-genuine-eur ... 059b9~oee/
https://www.ecstuning.com/b-genuine-eur ... 069b9~oee/
Crazy money at £44.00 plus vat each!
The part numbers seem to be on the database but couldn't find a diagram.
- lord-dudester
Gresley. Thanks very very much mate. That’s kind of you to take the time to post that
I’ll ha e look this eve and see what kind of clearance there is behind there and see if it’s worth having them on. A quick look at the shape of them I think I’d have to cut them down a fair bit.
My Etka has them listed at £56.16 each.
PR code E3A is for the "40 years GTI"
It looks as though the air dams mount to the chassis rail rather than the bumper, I'm guessing that the Clubsport has the two additional radiators the same as the Golf R which these feed air onto....
- lord-dudester
Doc. As always. Legend. Cheers mate. I’ll have a run through all the bits this eve
I’m thinking I’m going to do a dry run this wk end and offer it all up and see how it looks. I did have a look over matt at reflexes one when I was there a few months back but I can’t remeber if he had them in or not.
Edit. 45+ from TPS Peterborough and a 14 day lead time. So will defo try it before I buy em.
- lord-dudester
Found a few hours this morning for a dummy fit of the bumper. As expected the big vents ruin it. There’s not enough room behind them to get the ducts in so I’m thinking it’s gonna need some black mesh bonded to it from behind
- Grifnut
Bumper looks awesome
- Giddy
That bumper looks mental! I think custom made fog lights would fill the space nicely if there is enough room for them?
