What are the part numbers as TPS down in Devon will only serve you if you have the part number
Caddy 4 wheel drive build
- Sean1066
Re: Caddy 4 wheel drive build
- james400
The backing plates are for a rs3 not a caddy mateSean1066 wrote: What are the part numbers as TPS down in Devon will only serve you if you have the part number
- Sean1066
I need ones for R32 brake calipers 345mm
I thought they were 345mm
- james400
No mate the front ones are 370mm and the rear are 310mm that's what I have on now
- Barbel330
You don't need to change stone guards with R32 brakes. Standard caddy stone guards are fine. I still use standard caddy ones now with my Brembo calipers and 350mm discs.
Instagram: @y_5cuf
- Grifnut
This is going to be a beast, top job
- james400
Thanks mate its coming along slowly
- james400
Test fitted the wheels 2day
That’s lovely!!
- james400
Just a update so all the work under the van is now done so the big rebuild begins now new rear arms come 2moz so the weekend the coilovers can go on and start setting it up
- Barbel330
- caddychris2002
This is amazing what door cards are those mate. Stunning work
www.dav-tec.co.uk
www.facebook.com/davteceng
Autowatch Ghost Installer
Mods:
Mods:
- james400
It's getting there can't wait to start building it back up with all the new bits the door cards are Touran door cards but I've reupholstered them with the gtd fabric then fitted the lights in them
- Sean1066
This is really coming together top job buddy.
- Lister79
Awesome mate.
