Hi there chap odd question but do you happen to have a part number for the plastic trim that surrounds the radio and a/c controls. tiaLister79 wrote: ↑Sat Jan 05, 2019 2:29 pm Interior is getting there now, centre console in & dash 90% in, just need to fit the connectors for the floor lighting then I can fit the glovebox and light switch panel. A-post trims will have to wait until the van is outside. The red stitching on the steering wheel and gear knob will kill me but it will have to stay until I can justify buying a GTD wheel and knob.
Toffee delights
Re: Toffee delights
- BradleyB
Re: Toffee delights
I’ve not been upgraded yet so have no access
- Lister79
Re: Toffee delights
I think the dash trim is 1T085807R1QB but check with TPS first.
Re: Toffee delights
Cheers mate much appreciated
- Lister79
Re: Toffee delights
Well a nice weekend away started by the front passenger wheel taking a hit as I had to dyke the van to avoid getting the side taken out of it by a bus. The joys of driving on backroads. . Hopefully get it repaired next week.
I did manage to get a couple of photos before it ended up being covered in dust, so not all bad.
Fuming
Fuming
- Barbel330
- Lister79
Re: Toffee delights
Cheers Stu. Hopefully it will be sorted this week.
- robblowen
Re: Toffee delights
@Lister79 love the van mate, it looks awesome!
Quick question about the interior did you fit touran carpets front and rear? Where about does the rear footwell carpet finish? Cheers in advance.
- Lister79
Re: Toffee delights
Cheers mate.
Yeah it has Touran carpets fit front and rear the part where the two meet is around the centre of the front seat bases and the rear carpet section ends under the plastic trim that covers the front framework for the rear seat.
- robblowen
Re: Toffee delights
@Lister79 awesome, cheers mate
- Lister79
Re: Toffee delights
Got some real Carbon badges made for the rear, these should look better than the chrome.
- Lister79
Toffee delights
It’s the little things..... replaced the ESP switch for the later type with satin chrome trim to match the heater controls.
Before
Later type wiring diagram
After
Before
After
- brooneye
Re: Toffee delights
Ooh I like that, may have to pinch that idea. Take it it wasn’t to hard?
- Lister79
Re: Toffee delights
No mate just need to swap the connector over then it’s a straight swap.
- brooneye
Re: Toffee delights
You wouldn’t happen to have the part numbers?
