Please can someone help!
caddygirl
Post by caddygirl »
I have a caddy and she was in the garage last week loud clunking noise when running sounded like a bag of nails. A clutch repair kit was fitted. Now when I start her it sounds like the engine over runs for a couple of seconds . Is this normal.
Re: Please can someone help!
Can you explain what you mean by over running?
Does it run on when shut the ignition off?
caddygirl
Post by caddygirl »
No when I start the van it’s sounds like I have kept the key turned when I have let go.
Oh ok, so your starter motor is staying engaged for a bit longer than it needs to.
That may be a sign that it needs replacing or at least a service and lubrication.
caddygirl
Post by caddygirl »
Is there a way I can submit a recording please?
peely
Post by peely »
Sometimes if you have a duel mass clutch, a sign of wear is starter motor issues.
caddygirl
Post by caddygirl »
The clutch has been replaced, it’s only on start up, drives and goes through gears fine. I don’t totally trust the garage that did the repair but I had no option but to take it to somewhere close. It sound like it normally does but with a little extra growl on start up.
Your description definitely makes it sound like a starter motor that is slow to disengage.
Can you upload a video to youtube and post a link?
caddygirl
Post by caddygirl »
https://youtu.be/d0FEdY39eXg
Can anyone help please?
caddygirl
Post by caddygirl »
Also it’s worse the warmer it gets
caddygirl
Post by caddygirl »
caddygirl
Post by caddygirl »
