Which clocks can you fit in 06 plate caddy
As above which clocks would fit in 06 plate caddy
- r1lea
Re: Which clocks can you fit in 06 plate caddy
Any as far I’m aware mate, you don’t have component protection to worry about.
I’ve just fitted the latest Scirocco clocks I’m my mk4
- Sean1066
Hi r1lea
Do them clocks fit straight in to a mk3 facelift?
- r1lea
Yes, there all the same at the back, you just use your binnacle
The Rocco clocks with Rocco binnacle
The Rocco clocks with my caddy binnacle
- hef355
Yes Sean mate done mine last year, same as Lea’s but the R scirocco version, blue as opposed to red needles ... great clocks and i’m very pleased with them
- Sean1066
Thanks guys Is there any coding to do ?
- r1lea
Yes mate it’s not a plug n play thing
You need to get someone with the relevant kit for the immobiliser and mileage transfer as well as vcds for the coding
Depending where you are, doc did mine
They are far from a straight swap into a 06 caddy.
For 2010+ they are fairly straightforward to fit once coded up properly but 2015+ will have problems if there is ACC or factory head unit still fitted.
For the OP, you can fit anything from a red display midline (half height) cluster right up to the latest 3D colour display you see mentioned above into your 06 caddy. There are varying degrees of difficulty and costs.
What so theses Rocco clocks will go into 06 plate caddy , what's needed to code them in
ABS upgrade, CAN gateway upgrade, adaptor harness, new key transponders, some coding.
That's all really.
That's all really.
Not much then lol right would love them but sounds like it's a bit out off my league for coding
Would any one be willing to do it for some beer tokens
With the clocks I’m assuming I’ve got to buy diesel ones? Or doesn’t it matter is that a coding issue? Do the mk7 golf ones fit also ?
- r1lea
Yes you can use a petrol cluster as the coding will adapt it, but then obviously you’d need to swap the dials over from your caddy clocks which then makes it look exactly the same which is why I got a diesel version to keep the newer look
- Adie66
Just bin looking into changing my clocks in my 2008 maxi
What does it roughly cost for the coding ect
I just want a temperature gauge and mpg so dont want to spend a fortune
