Heko wind deflectors
I have just had my driver's side deflector blow off for the 2nd time while driving, it pops the top out on the rear edge, has anyone else has this?
Is it missing something?
Is there any way to know if it is the right one for a caddy? As it was already on the van when I bought it
Re: Heko wind deflectors
I have Heko wind deflectors and have never had this happen. I've had my windows fully down at 70mph and the deflectors stay put.
Have you fitted the metal clips to hold them in place?
No, I can't see any. Are they obvious?
Windows were up btw
Windows were up btw
I'm sure they were in a little bag packed along with the wind deflectors when I got them.
My passenger 1 is on the a46 somewhere saw it fly off on my way to caffeine & machine, quickest fix was remove the drivers 1 and the van is now a lot quieter at speed
Instagram @berger2k
They certainly are like a v shape and when window up pushing them in to position mate
@Berger lol, luckily the front of mine stayed in, so just had to fumble it back in blind while driving down the M5 at 70mph
I'll have to look into those clips
Iv stopped buying them for my van it’ll be on its 4th set if I bought some more, had one set blow off on m62 passanger side and I was in my van on my own, it hung on for dear life and I was trying to find a slip road. Had 2 sets stolen
Last set I drilled a 3mm hole in each just in case I see them on some ones van then there be needing 2 side windows as well.
And I bought a cheaper set that looked really solid in pictures but to get windows to go up and Stay up involved split second precision timing on the window switch lol.
I bought a set for my Rangey a while ago and they double sided taped to the outside, seems a much better design
Got them in my mk4 without clips and had Windows all the way down at 70 with no issues? Not using the metal clips either
Heko are sort of ok but Climair are the best, made in Germany and the quality is superb, no clips needed. Would recommend them all day long even though they are a bit more than hekos, around £50 for the x2 front doors delivered.
"of all the things Iv'e lost, I miss my mind the most"
I also have Heko deflectors on my windows, with clips.
Fitted soon after I got my Caddy and I've had no issues with them moving.
They are noisy but at least they stop water dripping in, when you have a window open, which is the reason I put them on.
well i'll look and see what the state of them is tomorrow. if I have no clips fitted, is there anywhere I can go out and buy them from? is somewhere like GSF going to sell them?
- NZDubNurd
I got CT deflectors that stick on the outside for my Touran. It's a much better design - like envycommercial said.
Hekos are sitting in my garage - totally can't be arsed with them! Moved the clips plenty of times, get everything in just the right place, then after a hot day with the windows down a crack... they stop the windows going up, or start rattling on the glass!
Stuck the CT's on, ZERO issues. They don't interfere with the windows or seals at all. Just like the genuine ones that came on my wifes Jap import Touran.
They're also available in multiple colours and different widths.
- Ripley55
I just bought the Heko’s about a week ago, they were super easy to fit, look nice and although I didn’t fit the 4 clips, they are still on.
If they do end up being pants, I’ll update but as nearly half the price of the Climair ones, good value
What’s the definition of irony ? I’ve always used wind deflectors as I was a smoker, but I’ve given up (8 weeks) so fingers crossed for me
well with mine, I came out to the van one afternoon, found the deflector bowed out, think the sun had been shinning on it and made it distort out. so the drivers side has been off ever since, but I do want something back on. might give the CT's a go, still trying to decide really. makes a big difference in the rain. I've been spoilt with heated windscreens. wish you could get them for caddys
