Brooneye's build
- brooneye
Re: Brooneye's build
@novakid If it’s the join on the two bumpers, they were hit stapled, plastic welded, filled and sanded. Took a lot of time and patience but well worth the effort
- brooneye
Sorry totally misread that
If it’s that grill it’s a touran centre grill with the chrome strip, but I had it sprayed gloss black and the strip and behind the badge sprayed red
- Novakid
This grill ?
When looking at the golf r bumper they all have a box cut out.
- brooneye
Ahh right I’m with you now, there’s that many.
You can buy it from vw for £240ish or there are cheaper copies on eBay
https://rover.ebay.com/rover/0/0/0?mpre ... 2726240255
I decided to go with a cheaper one as at the time couldn’t justify spending another chunk of change at the time
- Novakid
Cheers brooneye
Top job on the caddy mate.
- brooneye
Cheers, I’m getting there. Take it your doing a r bumper?
- Novakid
Yeah with a long list of other stuff
The bumper I have just now is a nice 1 not sure what it is, but after seeing the R bumper on the caddy cant see past it.
- brooneye
The list is forever growing pal, I was the same seen it and wanted it!!!
They do cost a lot in all the parts that are needed but worth it
- brooneye
Took advantage of an early finish last night, trip to a breakers for a panel but they didn’t have one, but I couldn’t help myself and came away with a set of front hubs.
Also washed and quick detailed it
Hopefully give it a polish over the weekend
- brooneye
Today I picked up a few parts from the painters and also picked my spare steel wheel up from the powder coaters
Just got to clean and seal it, can’t be putting a rusty wheel in the van
- brooneye
Had a bit of a productive afternoon, installed the sunlight sensor and got the last metal support out to expose the rear footwells.
Was left with this bracket
Does this need cutting down?
- brooneye
Not had much time to do much lately other than to keep it clean
Also last week got this parcel in the post
So that’ll be my little project over the next couple of weeks
- brooneye
Not been up to much lately, but my little project is still going on slowly in the background.
Today I get this in the post today
Got a couple of questions regarding it. I’m aware that I’ll need a special module to make the cruise work off the wheel. I have a 05 van but will I be able to use the newer stalks and slip ring with it?
Could someone point me in the direction of where I could find the part no for the airbag, I don’t mind reading through myself
I also got my new caddy2k stickers in the post
- Lister79
Nice mate, I had to fit Two additional modules on my 14 plate, one for the phone and another for the controls plus I had to install basic stalks (without cruise). You’re best of contacting Spacewalker as he will confirm if what’s required with your slipring etc (you will need to sent him a recent autoscan).
- brooneye
Brooneye's build
Cheers pal I’ve been after one for ages, they all seem to be pricey with damage or extremely pricey with none and I got this for a bargain.
I knew I’d have to get in touch with spacewalker for one of his super duper modules. Did you you get both off him?
At present I have cruise off the stalk and will have to revert back to normal stalks and that’s why I was wondering if the newer shape golf stalks would work on mine.
