New to caddys
Mulldutch
New to caddys
Post by Mulldutch »
Hi guys iv bought a 2005 caddy last week and just bought a mk1 touran last night for parts. Just wondering is the carpet a direct fitment to the caddy ?
Re: New to caddys
Hi, welcome to the forum.
The front carpets are a straight fit into the Caddy, yes.
There are lots of parts you can swap over, it's probably one of the most discussed topics on this forum.
Mulldutch
Re: New to caddys
Post by Mulldutch »
Thanks doc iv converted everything over including the dash . Just one question what do i need to get the teip computer working as id like to see how many miles i have left in my tank ?
Brechin47
Re: New to caddys
Post by Brechin47 »
does anyone know if its a straight fit for touran clocks?
ziggmike93
Re: New to caddys
Post by ziggmike93 »
It would be awesome if the clocks was a direct fit - how much of a touran have you swapped over so far?
claudiu2s
Re: New to caddys
Post by claudiu2s »
Brechin47 wrote: Fri Jun 14, 2019 7:44 pm does anyone know if its a straight fit for touran clocks?
if the touran clocks are similar with the Caddy ones red and blue background light will fit but u need special tools to do the coding and the clocks hold IMMOBILISER. if the clocks are not coded the van will start for 2-3 seconds and then will stop as IMMO will stop it. If local i can code them for u.
vcds.diagnostic@gmail.com
Bradbongo
Re: New to caddys
Post by Bradbongo »
hi im just wondering if the rear carpet is easy to swap over also thank you
