BradleyB
Post by BradleyB »
Berger
Another nice mod mate
Is it direct fit or was there some cutting involved
Berger
Post by Berger »
Thanks no cutting involved just had to remove the pin holding the original handle in then swap it for the golf 1 there exactly the same the only thing is you can’t buy the handles separately they come as part of the door card because there plastic welded in but wasn’t hard to change and I’m useless at this kind of thing
Instagram @berger2k
owencardew
Post by owencardew »
r1lea wrote: Fri May 03, 2019 5:05 pm Swapped the stalks to mk7 golf stalks ImageImageImageImage
Hi r1lea,
Would you mind sharing the Part Numbers for your Stalks and Slipring? I am working on fitting the same MFSW to my Caddy Mk4 and it would be great to have some part numbers to order stuff that actually works with the Mk4!
Much Appreciated!
2016 Caddy Maxi 2.0 TDI with a variety of Mods & Retrofits including RaceChip Pro 2, 18" Alloy Wheels, Bi-Xenon Headlamps, 6C0 MFSW, OEM Electric Windows + Electric Folding Mirrors Retrofit, Composition Media Retrofit, Arteon Carbon Leather Electric Seats and Audison Audio Install.
r1lea
Post by r1lea »
First of all mate what steering wheel
Are you fitting ?
That will depend on the stalks and the slipring you need
Edit : just seen your other post
The pic you posted of the polo wheel is the one you ideally need
That has red illumination and is without cruise which will work on your van
You’d then keep the cruise control on the stalk
You’d need a highline steering module / slipring, mine was 5K0 953 569 BD
To go for a mk7 golf wheel like mine with cruise on requires an aftermarket module made by “spacewalker”
owencardew
Hi r1lea,
All the steering wheels listed on eBay mention Golf, Polo, Passat etc in the same description. What three digits should i be looking for in the Part Number? 5GO etc etc...
r1lea
Post by r1lea »
I’m sure it’s 6CO mate
Doc will confirm
Yes, 6C0.
There's plenty of discussion on the forum about this, no need to go off topic on this thread.
frasermcq
Post by frasermcq »
Made a start on sound proofing.
Picked up some Car Builders Stage 1, similar to Dynamat I think. Available locally here in Adelaide, so worth a try. Cheaper too. Doing the rear “window” panels and wheel arches to start with, then rear roof, cabin roof and anywhere else I can get it into. Here’s a couple of the usual “started sound proofing” pics. Aiming for a bike/camper build, so see how we get on.
bob86
Post by bob86 »
Started work on the rear floor, going to be a false floor with some storage space
Going to have to leave a little bit of room on the side of the top panel for the insulation and carpet that will be going on the arches (forgot to leave this space around the base board but it's not going to get taken out)ImageImage
Post by Stedlocks »
mikenorman wrote: Thu Apr 25, 2019 9:52 pm That ok sir?
Have you fitted your wheels yet fella?
I am about to pull the trigger on a set from them with the same dimensions.....the site 'willtheyfit' seems to suggest the poke will be considerable? I'm not knowledgeable enough to know if 30.4mm at the front and 40.1mm at the rear will work, while still being able to open the door?
Post by Stedlocks »
Oh, and I've just bought the Stance + coilover kit, on the recommendation of a local chav! :lol:
Novakid
Post by Novakid »
bob86 wrote:Started work on the rear floor, going to be a false floor with some storage space
Looking good mate,
You carpeting the walls also ?
Are you planning doing ply or just follow the shape?
bob86
Post by bob86 »
@novakid
Yep full carpet on ply, I've got some stuff that was in it when I got it, but it's all splitting on the back side where it curves, so I may just do new. Will be carpet on all metal though, and carpeting the roof panels too, just need to work out how I'm going to have the rear interior lights coming thru the carpet.
Novakid
Post by Novakid »
Nice, be Interested in seeing how u fix the ply to the panel.
Loaded up and went camping for the weekend with the missus. We’re just by Trearddur Bay on Anglesey.
Sent from my iPhone using TapatalkImageImage
