Caddy Rouge
- Caddyluv
Re: Caddy Rouge
Static plates. Just put 1 on mine. Held on with static electric amazing.
https://www.staticplates.com/
- btaylor2k
Re: Caddy Rouge
They look good! Wonder if they will stick to the inside of your windscreen?Caddyluv wrote:Static plates. Just put 1 on mine. Held on with static electric amazing.
Kerbside Kustoms
- Caddyluv
Re: Caddy Rouge
Be the wrong way round. They are soft sponge. No damage, just rinse if they get dirty.
- btaylor2k
Re: Caddy Rouge
Oktoberfest VW show show and shine today,
Kerbside Kustoms
- btaylor2k
Re: Caddy Rouge
Lovely caddy mate.
- btaylor2k
Re: Caddy Rouge
Thanks dudeCupra.al wrote:Lovely caddy mate.
Kerbside Kustoms
Re: Caddy Rouge
Hi can I ask how you went about making the light in the back?? Fixing points etc? I fitted a strip light in mine but looks pretty shit as it bows because there’s no where to fix it!
Re: Caddy Rouge
Great build mate. Top work
- Damo2k
Re: Caddy Rouge
Very nice van matejust add a ton more jobs to my list
Sent from my SM-G935F using Tapatalk
- RKDesigns
Re: Caddy Rouge
Nice built
- btaylor2k
Re: Caddy Rouge
We gook a piece on ply and stripped it down to 200mm wide x full length of the van, screwed that on to a bit of 3x1, carpeted it, put led strips on the edge of the 3x1 then screwed right threw it in to the ply headlinerChrispope26197 wrote:Hi can I ask how you went about making the light in the back?? Fixing points etc? I fitted a strip light in mine but looks pretty shit as it bows because there’s no where to fix it!
Kerbside Kustoms
Re: Caddy Rouge
Thanks! How did you fix the ply to where the headliner is?
- btaylor2k
Re: Caddy Rouge
Did 1 sheet of ply cut to headliner shape, carpeted thatChrispope26197 wrote:Thanks! How did you fix the ply to where the headliner is?
The make a small 5mm slit in the carpet, pulled the carpet back so the screws dont bugger up he carpet then screwed up in to the roof support bars, then just tuck the carpet over the screws again
Kerbside Kustoms
