Toffee delights
Azz03
Re: Toffee delights
Post by Azz03 » Fri Jun 07, 2019 8:36 am
@lister79 ah sorted then I guess that’s another mod I can look into doing are your ones the vanstyle ones? Thanks for the info and replying
Lister79
Re: Toffee delights
Post by Lister79 » Fri Jun 07, 2019 3:45 pm
Yeah just the Vanstyle ones mate.
2011 White 1.6TDi with EA888 CJX engine
2014 Toffee Brown 1.6TDi
Azz03
Re: Toffee delights
Post by Azz03 » Fri Jun 07, 2019 9:56 pm
Thought so not a bad price for the full set either. Thanks again
Lister79
Toffee delights
Post by Lister79 » Sun Jun 09, 2019 3:58 pm
Fit the arches to the rear bumper and made up some mud flaps. The fit of the arches against the bumper shape isn’t what I’d call perfect, tried heat which improved it slightly but still not 100%. Looks like the radius should start slightly lower, couldn’t drop the arch down as then the top would be wrong. Hopefully I’ll forget about it Image.
Also removed the front bumper and put the original one back on so I can drop the custom one off at the body shop tomorrow to be repainted. Had to remove the fog light due to the screenwash bottle now being in the way.
Sean1066
Re: Toffee delights
Post by Sean1066 » Tue Jun 11, 2019 6:34 am
Them arches look the part lister.
Were they hard to fit ?
Ex BG 2011 Caddy maxi CR20 TDI, Remapped to 140,
My build thread
Lister79
Re: Toffee delights
Post by Lister79 » Tue Jun 11, 2019 1:52 pm
Cheers mate, I’m really pleased with them. Not hard to fit just a bit of time required getting the fronts right against the MK3 wing and hybrid bumper shape. But I’m not a bodywork person so could be a piece of piss for someone who is used to doing it.
Lister79
Toffee delights
Post by Lister79 » Tue Jun 11, 2019 3:39 pm
So after Ryan (Caddyluv) produced a spec list for his Caddy thought I’d follow suit. Think I’ve got everything.
Base van:
2014 Toffee Brown 1.6 TDi Trendline.
Engine Bay:
Genuine engine cover, painted to match body.
Golf R “Black” Coolant reservoir cap.
Genuine “Black” Screen wash Bottle cap.
Relocated Screen wash bottle.
MK7 Golf Dual tone horn.
Genuine Bonnet sound deadening (Silent coat also applied).
Genuine engine under tray.
MK5 Golf wiper nut covers and scuttle panel bungs.
Engine:
Currently standard.
Suspension and Chassis:
Meister R Zeta+ front coilovers.
Whiteline 24mm adjustable antiroll bar.
Full Powerflex bush kit in lower arms.
Bilstein B6 rear shocks.
Axle flip with Darkside Performance rear shackle and hanger kit.
Rear hanger blocks.
Powerflex Black series bush kit in rear springs and chassis mount.
Chassis fully Waxoyled and all components repainted Black.
Brakes:
Brembo 18Z front Calipers (painted yellow) with PW Motorsport mounting kit.
Golf R32 disc backing plates.
350mm Drilled and Grooved discs (Mtec Brakes) with Brembo pads.
Hel Braided brake hose’s.
Rear currently standard (painted yellow).
Body:
Hybrid MK7.5 Golf GTi front bumper with Genuine Foglights.
Maxton Version 2 front splitter.
Touran front grill.
MK4 Caddy rear bumper.
Custom Touran/Caddy wing mirrors.
Edition 30 Side mouldings.
Modified Audi A5 side skirts.
Modified Vanstyle MK4 arch kit.
Rear spoiler.
Painted number plate light handle.
Side rail cover (with correct rail).
Black rear VW Badge with painted backing.
Custom real Carbon fibre badges with yellow glass inlay on “i” (Caddy & TDi).
Custom EM Tuning Bi-Xenon headlights.
MK4 Caddy side repeaters.
MK4 Caddy rear light units with LHD version fit to driver’s side.
Wind deflectors.
Mudflaps.
LED Bulbs throughout.
300mm Pressed plates.
Interior:
Fully sound deadened and insulated (front and back).
Rear fully carpeted in Anthracite carpet (with ply panel inserts).
Additional LED roof lighting (on separate switch).
USB charging point in rear.
Coffee Ash wood flooring in rear.
Armour plates on rear doors.
Rear door interior release handle.
Touran rear seat conversion.
Touran Carpets (front and Rear).
Touran seat bases.
2018 Golf GTD heated front seats (wired with stans loom).
Touran Dashboard.
Wrapped dash trims.
Facelift Touran vents and ESP switch unit (satin chrome trimmed).
Touran centre console with cross stitched arm rest.
Leather handbrake cover.
Yellow Seatbelts (front and rear).
MK7 Golf GTi Gearknob with shortened lever.
MK5 Golf GTi foot pedals.
MK6 Golf GTi flat bottom MF steering wheel.
Passat W8 interior light.
Auto headlights.
White LED door and floor courtesy lighting (door open).
Red ambient floor and door pocket lighting (front and back).
Touran Door panels, reupholstered in GTD tartan.
Audi A8 door handle lighting diffusers (red).
Alpine door speakers and Alpine 6x9’s installed under front seats.
Satin chrome tipped window switches.
RCD510 Headunit.
Genuine VW touran carpet mats (front and rear).
Genuine VW rubber mats (front only).
Upol Dark grey pillar & roof trims (in progress).
Wheels:
19” Mercedes AMG, powder coated in BMW Ferric Grey with diamond cut faces and powder lacqured, (8.5” wide ET45).
Goodyear Eagle F1 Asymmetric tyres (225/35 19).
Caddyluv
Re: Toffee delights
Post by Caddyluv » Tue Jun 11, 2019 6:05 pm
You sure that’s everything
Azz03
Re: Toffee delights
Post by Azz03 » Tue Jun 11, 2019 6:08 pm
Wow that’s one long mod list and I bet your not even finished haha not going to lie one of my favourite vans on the forum can’t get enough of the colour
Lister79
Toffee delights
Post by Lister79 » Tue Jun 11, 2019 7:54 pm
I think so Ryan, I’ve been going over it for a few days and every time I got in it I kept thinking of more.
Ha ha I don’t think it will ever be finished Azz03, still loads to do, rear seats to recover, R32 rear brakes, alloy front subframe, narrowed maxi rear axle, air suspension etc etc. It was always going to be a long term project so I’ll just keep plodding away with bits as and when the funds allow. Thanks for your comment it’s much appreciated. It’s one of those colours that you either love or hate. In the sun it’s beautiful, but when it’s dirty, not so much. Mind that could just be my excuse to my wife why I need to wash it so much.
Azz03
Re: Toffee delights
Post by Azz03 » Tue Jun 11, 2019 8:05 pm
Lister79 haha yes there’s so many mods you can do to a caddy as I’ve learnt from joining the forum. Oh it’s definitely a colour I love 1. you don’t see many in this colour and 2. it just stands out to me I bet it does look mint in the sun. Haha I can agree with you there I tell my wife I’m doing quotes and invoicing yet I’m always on the forum haha
Lister79
Re: Toffee delights
Post by Lister79 » Tue Jun 11, 2019 8:08 pm
Tyler
Re: Toffee delights
Post by Tyler » Tue Jun 11, 2019 9:27 pm
stunning caddy you have there mate. love the colour
Lister79
Re: Toffee delights
Post by Lister79 » Wed Jun 12, 2019 3:09 pm
Cheers mate
Lister79
Toffee delights
Post by Lister79 » Fri Jun 14, 2019 5:34 pm
Finally got round to fitting the Carbon rear badges this afternoon. I like the look against the brown paintwork but one thing that might be an issue is they don’t sit as tight to the body, so may catch on cloths etc when I’m cleaning it, will just have to see how it goes.
