Irratic idle when cold goes when warm any ideas
As above guys tried doing a bit off research can't seem to bring anything up
Re: Irratic idle when cold goes when warm any ideas
Carry out injector leak off test
Is that done via Vcds mate
There's injectors test looks fine too me
- Boonalon
There is a micro quantity calibration that can help with symptoms like you have at times but you need ODIS, I did a golf last week with same complaint
No mate you will need to take to garage. Basically you remove the leak off pipes from injectors then fit separate pipes to injectors. Start engine and see which injector is giving a lot of return fuel over a period of about 30 secs. Whichever one(s) give off a lot of fuel needs replacing
Right so need to get to garage then
