My EX BG VR6 3.2 build
- Sean1066
Re: My BG Caddy maxi build
Been doing a bit today got my slip ring module ready to go in to take my Mk7
MFSW
Burnt my finger on the soldering iron
MFSW
- Svenycaddylife
Got my vents in
- Sean1066
Very nice buddy.
The A3 vents look really nice on a caddy
- Svenycaddylife
Just needs some thicker foam between the vent and ducting to make a snug fit
What else have you done to get them to fit properly? I’ve seen a couple of pics where other people have fitted them but they don’t always look quite right.Svenycaddylife wrote: ↑Mon Aug 05, 2019 6:38 pm Just needs some thicker foam between the vent and ducting to make a snug fit
- Svenycaddylife
The bottom of the dash needed small bit of plastic cut out that was it they are easy to get back out again
- Timson
Nice work! I love this build, gives me a lot of inspiration for my own maxi.
Awesome thread, some really good inspiration for all us fellow BG van owners, keep us updated dude
- Svenycaddylife
This is how much I cut out to give a snug fit the first one I cut a little to much but it still stays in the hole okBeardyginge wrote: What else have you done to get them to fit properly? I’ve seen a couple of pics where other people have fitted them but they don’t always look quite right.
- Sean1066
@Dan4da thank you for your nice comments
I always try and keep this build update.
@timson thank you for giving me the inspiration to keep on building. Hopefully you will start a build to inspire others.
- Sean1066
Well after a lot of headaches I have finally got my spacewalker module all wired up. Fitted in my caddy and got my Mk7 golf MFSW fitted and working.
Now I think that looks a lot better
- Svenycaddylife
Looks epic
- Timson
That steering wheel looks amazing! I would like cruise control too. Is it possible to change the steering wheel like you did and code in the cruise control to work? So instead of a cruise control stalk I mean. I would then choose a MFSW over a stalk kind for convenience and the fact that you can also control the radio, etc.
- Sean1066
@timson
You will have to get a spacewalker module to do that.
Then you will have to do some soldering like I did
- Timson
Are there no MFSW's that do not require soldering in order for the cruise control to work? Like MFSW's from other caddy's?
