Avalanche wrote:Took my caddy for a long drive, the mpg is getting better with more miles on the clock 60mph on motorways and speed limits everywhere else
Did you do anything to get it running better, best I can get normal driving is 55 odd MPG, dropping to high 40s on motorway
Boonalon wrote: ↑Sat Aug 03, 2019 6:40 pm
Engine is standard, and without emissions update. It’s lowered 40mm on the front.
I found that once I drive it much over 60mph the mpg really starts to drop, but with congested roads you rarely get anywhere much quicker. I was considering swapping to a T5.1, but I know the mpg will be considerably less.
Giddy wrote: ↑Sun Aug 04, 2019 6:52 pm
Started carpeting back of the van. One side done now. Truly awful job to do and takes forever to do it on your own.
@audi5inline It's there since I removed it from underneath. Considering to get a space saver and fabricate some sort of bracket, so I can bolt it to the bulkhead
Giddy wrote:@audi5inline It's there since I removed it from underneath. Considering to get a space saver and fabricate some sort of bracket, so I can bolt it to the bulkhead
Ok, i have a 4 motion and dont have a spare under the car because of the diff so Why did you remove it from underneath the car ?
daz-uk wrote: ↑Sun Aug 04, 2019 7:43 pm
Had mine lowered, MK4 rear lights, electric windows fitted, and flat bottom steering wheel, all fitted by Caddy solutions.
Love those lights. I need some for mine but struggling to find what to go for. Are they smoked and did you go for the LHD version to keep the 2 x reverse lights?
