My EX BG VR6 3.2 build
Sean1066
Re: My BG Caddy maxi build
Post by Sean1066 »
Not 100% sure
Caddy maxi 3.2 VR6 EX BG
My build thread
claudiu2s
Post by claudiu2s »
Timson wrote: Thu Aug 08, 2019 9:13 am Are there no MFSW's that do not require soldering in order for the cruise control to work? Like MFSW's from other caddy's?
if your van is 65 plate or above then u can use a Scirocco/Polo steering wheel with cruise and highline slip ring. If the van is pre 65 plate then u will need that special module Sean installed.
vcds.diagnostic@gmail.com
Timson
Post by Timson »
I'm not familiar with the plate system as I am from the Netherlands. A quick google search shows me that a 65 plate was registered in september 2015. Does this mean that the fabrication year of the van must be 2015 or up? My caddy is produced in 2011.
Sorry for hijacking your build thread Sean!
Sean1066
Post by Sean1066 »
@ Timson 65 = the year the caddy was registered
So 65 is the year September 2015 to March 2016
My build thread
Timson
Post by Timson »
So that's the year of production of the vehicle? That means I would have to resort to the same way you made your MFSW work? Seeing as my caddy has the same production year as yours.
Nubnubb0r
Post by Nubnubb0r »
Where do you get these spacewalker modules from then? Also cracking looking van, was wondering if yiu used the same bumpers or got Touran ones sprayed as I would like mine doing just do not know which is easier?
Sean1066
Post by Sean1066 »
You can get the spacewalker module from this website
http://forum.xhorse.pl/viewtopic.php?f= ... 0bae4a373f
I got my bumper from gtikris on instagram.
It’s made from a caddy bumper and a Mk7.5 Golf R bumper.
My build thread
Nubnubb0r
Post by Nubnubb0r »
Ahh sweet. Were they the right colour then? That took me to a coding site. Take it its a standard module that you change using these tips?
Sean1066
Post by Sean1066 »
They come like this
Image.
For the module just click home and look for the MFSW
My build thread
Sean1066
Post by Sean1066 »
I do like my new C2K logos
My build thread
Rossy888
Post by Rossy888 »
Hi sean1066 love these bumpers could you tell me where i could get one from many thanks
Sean1066
Post by Sean1066 »
I got mine from a guy on instagram gtikris
My build thread
Rossy888
Post by Rossy888 »
Ok thanks
Sean1066
Post by Sean1066 »
As low as I can now without air ride.
Must admit it looks a lot better
My build thread
Svenycaddylife
Post by Svenycaddylife »
Looking good. I acquired some h &r springs on newish shocks the other day just need to get flip kit and find time to do it
