Torque settings
Novakid
Torque settings
Post by Novakid »
Could someone tell me what the torque (NM) settings are for these bolts.
Arrows and numbers because I am not sure what they are all called.
It's a Asz engine.
1- Rocker bolts
2- main cylinder head bolts
3- injectors holding bolt
4- not sure what they are called but it's the vlock that the rockers sit on top off and hold the cam shaft down.
Thanks.
Sean Image
Re: Torque settings
1 KN is a 1000 newton meters. I’m no engine mechanic but I very much doubt you’ll be tightening up to those values. I’d say your best measurement is NM or Ft-lbs.
A Haynes manual would give you all this information, and would be a worthy investment if you’re carrying out this sort of work.
Hope you get sorted mate
Novakid
Re: Torque settings
Post by Novakid »
Sorry you are correct its NM
Only plan in doing this job once hopefully.
Will edit the post.
Cheers for that
Re: Torque settings
No worries mate. Yeah you’ve been at this a while now, bet you’ll be glad to get it done and ok the road.
Novakid
Re: Torque settings
Post by Novakid »
Can't wait to get it running now only timming belt to be done then put it back in and turn the key.
Been flat out on other jobs and kids on holiday so not getting much time on it but will get there in the end.
Re: Torque settings
Hope it starts first time!!
Life gets busy.....it took me 2 years to get mine lowered
Adie66
Re: Torque settings
Post by Adie66 »
2 mins mate an ill get u a photo from my manual of all the engine torque settings its asz i assume
Adie66
Re: Torque settings
Post by Adie66 »
Them are all the settings for the asz ImageImage
Exuse my bad drawing Image
Novakid
Re: Torque settings
Post by Novakid »
Some boy adie66
thanks
Adie66
Re: Torque settings
Post by Adie66 »
No worries buddy let me know you need any others info from the manual an ill put photos up of what u want
Re: Torque settings
Remember that any bolts rated for a 2 stage tightening according to that book will be a stretch bolt which will need to be replaced rather than reusing the old one. Remember to clear out any oil that might run into blind holes before inserting a bolt as the oil may cause it to hydrolock and torque tighten before correctly loading as desired.
Novakid
Re: Torque settings
Post by Novakid »
Cheers for that doc.
Will be replacing the bolts.
Adie66
Re: Torque settings
Post by Adie66 »
Just wondering are you replacing the bolts with genuine ones or are you getting the non strech bolt from darkside developments ?
Would like to know what the torque settings are on the non strech bolts as i need to pull all my injectors out so will need to replace the bolts
Novakid
Re: Torque settings
Post by Novakid »
Darkside and this is the torque settings that come with them.
I was comparing the difference on genuine ones at the start.
Adie66
Re: Torque settings
Post by Adie66 »
Sorted thanks for that ill get all my bolts ordered from them
