My EX BG VR6 3.2 build
- Sean1066
Re: My BG Caddy maxi build
Not 100% sure
if your van is 65 plate or above then u can use a Scirocco/Polo steering wheel with cruise and highline slip ring. If the van is pre 65 plate then u will need that special module Sean installed.
vcds.diagnostic@gmail.com
- Timson
I'm not familiar with the plate system as I am from the Netherlands. A quick google search shows me that a 65 plate was registered in september 2015. Does this mean that the fabrication year of the van must be 2015 or up? My caddy is produced in 2011.
Sorry for hijacking your build thread Sean!
- Sean1066
@ Timson 65 = the year the caddy was registered
So 65 is the year September 2015 to March 2016
- Timson
So that's the year of production of the vehicle? That means I would have to resort to the same way you made your MFSW work? Seeing as my caddy has the same production year as yours.
Where do you get these spacewalker modules from then? Also cracking looking van, was wondering if yiu used the same bumpers or got Touran ones sprayed as I would like mine doing just do not know which is easier?
- Sean1066
You can get the spacewalker module from this website
http://forum.xhorse.pl/viewtopic.php?f= ... 0bae4a373f
I got my bumper from gtikris on instagram.
It’s made from a caddy bumper and a Mk7.5 Golf R bumper.
Ahh sweet. Were they the right colour then? That took me to a coding site. Take it its a standard module that you change using these tips?
- Sean1066
They come like this
For the module just click home and look for the MFSW
- Sean1066
I do like my new C2K logos
- Rossy888
Hi sean1066 love these bumpers could you tell me where i could get one from many thanks
- Sean1066
I got mine from a guy on instagram gtikris
- Rossy888
Ok thanks
- Sean1066
As low as I can now without air ride.
Must admit it looks a lot better
- Svenycaddylife
Looking good. I acquired some h &r springs on newish shocks the other day just need to get flip kit and find time to do it
