Can someone share the link for the how to coding please. I have obdevelen pro & a genuine vcds but just want to check I code in all relevant modules
upgrade headlghts
Re: upgrade headlghts
I’ve also seen this as option
Where by you get the power from the battery directly rather than via the canbus since the voltage is lower than it should be.
https://shorturl.at/ekmAY
Never fear, in & sorted. Harness needed the tape cut back as was too tight to reach the pins from halogen position as the xenon version the plug is further towards the outside edge of the van
Bit of trial and error. I will pull my coding when I’ve got the van back as it’s currently at bodyshop getting a couple of bits colour coded then early next week having front coilovers replaced. Remind me Thursday as I will have it back
Upgrading to bi xenon’s, is the coding straight forward?!
