Sunroof/Panoramaroof Caddy
- x_p_e_r_t_1
Hi guys,
I have got an impression that there are some cars with rear sunroof latch options on Caddy 4 and onwards as options rarely added (Common if you might be a surfer), But have any of you guys seen a Caddy 3(facelift) with either sunroof or panorama skyview roof as oem?
Re: Sunroof/Panoramaroof Caddy
As far as I'm aware a factory only option
The only thing I’ve ever seen is this. It’s called a ladder light apparently and is very rare, but is OEM. The van is about a 54 plate too. I’m not sure for how many model years it was an option.
A mate had one before but it was on a 2006 Model. Dont see many about
Factory sunroof was never an option.
There are possibly some aftermarket options.
The ladder hatch was available from 2004-2020 but a very very rare find. If I remember correctly there was a fleet of UK Caddys from 2006 or 2007 which had these.
- x_p_e_r_t_1
Thanks for the info. will have my 2nd search up for the OEM option ladder type, If someone knows or come by about a "oem" like aftermarket/retrofit option with the sunroof further front or panorama, please don't mind to share;-) Lets see maybe its a custom "retrofit"...
- gazza31112
I'd have absolutely no use for it...... But I want it
I’m sure a full length panoramic roof could be retrofitted. As for removing metal, it wouldn’t be a million miles away from installing a pop top. Depends on how much money you want to spend.
Id be really interested to see the result. Keep us posted mate
I wanted one for the ladder light but could not find one
- adeybroth
Sure I saw an add recently for a Caddy life that had a sunroof.
- NornIron
Would replacing the roof panel with a Touran Panoramic Sunroof panel be feasible (albeit expensive!)
Ich habe kein Geld!
- x_p_e_r_t_1
OK, Lets see what options I come by and of course if it's reasonable, will keep updating especially when in a realistic mod possible here.
- Bahnstormer
There's a Caddy which has popped up in a couple of DTE's vids which has a panoramic sunroof fitted. IIRC it's from a Mini or something like that? I'll try and find a video when I get home.
- x_p_e_r_t_1
OK, I will have a look on that as well.But, Meanwhile in the research I have found that in our regional brochure in Norway from when the Caddy was new for sale/order at dealer there was a option to add inn roof oem in our country:(Page 27 in the brochure)
https://www.yumpu.com/no/document/read/ ... yttekjrety
Any new thoughts on this?
Look’s exactly like what I need.
