As a newbie I am happy to see that a big part of south Sweden now are covered (Skåne, Västergötland and Uppland) . I inspires by both yours and poff”s threds .snuffegull wrote: ↑Fri Apr 19, 2024 7:18 pm There seems to be a fair few Swedes here! I'm in the Uppsala area
Re: Caddy Maxi - daily and camper build
Caddy Maxi 2.0 TDi 2016 (DFSD, 2KN) 18’km
"A chance comes like a snail and disappears like a lightning"
Todays 5min job that took 6 hours to complete:
Rear torsion bar bushings. First two bolts snapped within the first 5 minutes. Last two came loose with some rust penetrating spray and a lot of heat.
Spent a long time trying to weld on some nuts to the broken bolts. When that failed I used a bolt extraction together with some heat. Ended up making the situation worse and snapped the extraction tool inside one of the bolts. Went back to welding and managed get them loose in the end.
Sent from my Nokia 3310
Man what a stinker! I did this on mine a few weeks ago, and luckily only one snapped, and i got it out first try when welding a nut to it. but when that doesnt work its such a pain in the ass
Yeah, it sucks! I had more plans for the car over the weekend, but that put me of doing any more work. Had initially planed to change the rear spring bushings as well. But now i realise i better get new bolts before starting that job.snuffegull wrote: ↑Thu May 09, 2024 9:15 pm Man what a stinker! I did this on mine a few weeks ago, and luckily only one snapped, and i got it out first try when welding a nut to it. but when that doesnt work its such a pain in the ass
