Caddy cut out wont start ?
Flameboi201
Post by Flameboi201 »
2004 caddy 1.9 tdi 99000 miles full service history . Rite here goes . Driving down the road today van just ran lumpy for a couple of seconds . Then cut out . Pulled over , tryd to start and nothing ! Towd it back to my workshop . Still nothing . Gave it 5 mins and with my foot flat to the floor it started again ran for ten seconds then stopped again . Took the fuel pipes of the filter , put the ignition on , no fuel , didn't prime .so cranked it over still no fuel . So thort fuel pump . Took the tank out . Fuel pump out and powerd it up on the bench, works fine . So I connected it back up and nothing . Checked every pin in the connector and not a single live .should there be a permanent live or will it be switched ? Shorly ther must be something ??? Checked fuses and stuff all seem ok . Any ideas guys ???
Re: Caddy cut out wont start ?
Fuel pump relay! Think it's in the engine bay.
Flameboi201
Any idea wich 1 it is ?
Just looked it up on Google,
Cabin relay box below the steering, Relay 409.
Flameboi201
Thanks dude will check it tomoz and let you no . Any one had the pump fail ?
Cryptwalk
Post by Cryptwalk »
Mine failed, swopped it with the horn relay to get me home, it's where doc said right side cabin above fuse box.
Flameboi201
Ther is no relay 409 . ? A couple of 449 . And a 53 . Any idies witch relay is for the pump ?
409 may be a mk4 relay
Are the sockets numbered?
Think it's J17.
Have you a multimeter to check each relay if it came down to that?
Flameboi201
Not numberd no .and my one failing is wireing . Had vag com on it . And the only codes it brings up is fuel temp sencer . I filled fuel filter up and it ran for about 1 min on tickover then stopped . But I just Carnt figure out witch the fuel pump relay is . I've googled it and Carnt find owt of use ;-( so I'm stuck lol
Adam87
Post by Adam87 »
This any help
Flameboi201
Not sure really mine looks nothing like that lol .
Adam87
Post by Adam87 »
It's the bit inside above the cecm, you will have to take the trim panel off to see it and it will probably only have a few relays in it
Flameboi201
This is what is under my steering colum
No pump relay
Adam87
Post by Adam87 »
Yes all the vans do until 2010-2011, it's higher up than that unit, it's just a plastic cage that houses them
Flameboi201
I'm not shore there is anything above that . I'll check tomoz tho . Cheers
