Touran 6 speed gearbox
garyw20
Any1 know if a touran 6 speed gearbox from a 1.9 TDI will fit a BLS engined caddy ? I'm assuming it is an easy swap but just want to b sure before purchasing.
fenwick458
Re: Touran 6 speed gearbox
theres more than one type of gearbox. 02M, 02S, 02Q etc... they all fit, but some require more or less to be changed. and they all have different ratios (identified by the gearbox code, (DRW, ERF, FMH, GQN, GQMand some of the 6th ratios are only a little bit higher geared than 5th in a 5 speed box
garyw20
Cheers for that. Do u knw which 1's r best? And which are highest geared. That's main reason for wanting to upgrade. 5th n caddy is too low geared.
fenwick458
I only know about the 02M versions (mk4 golf) and of them, the DRW has the highest ratios, the EFF has the lowest, and the ERF is sort of a compromise between the 2.
the 02S boxes have some really short 6th gear ratios, but thats all I've heard never really read much into it. google it i'm sure you'll find sommet
garyw20
That's great. Most people seem to have used ERF and DRW boxes. Do u knw what the DRW boxes wer originally fitted too? ERF seems to have been 115/130 golfs.
fenwick458
DRW was the 115's, EFF was early 150's, well over 2/3rds of the 130's are all ERF, as are the rest of the 150's.
garyw20
Cheers for that. All makes so much more sense now. Will hold out for 1 of these boxes I think as I want low revs when I'm on the motorway.
fenwick458
garyw20
Thanks mate.
K3YWO
I have a 02M gearbox in my caddy at the moment but want to change it if possible to get a better motorway cruising speed, Can anybody tell me where the gearbox code is located on the gearbox as i cant see it!?
- Gibbo185
86drift
There doesnt seem to be much between the DRW and ERF boxes but i suppose if looking for most mpg on motorway miles may as well go for DRW if going for the swap.Nice info,cheers for sharing.
quad_man
I running erf now if anyone wants to try it out
I recommend the swop
loads better on motorway
86drift
Thinking of going this route too as my flywheel needs changing anyway,what revs do you find doin at say 70mph in 6th with the ERF box?quad_man wrote:I running erf now if anyone wants to try it out
quad_man
2000 if i was doing 70 but i never do 70 not in 6th anyway
