Maxi life build
- torque777
Re: Maxi life build
I bought the bars allready wired, but you take the two wires to either the front or rear side lights
Re: Maxi life build
Cheers.
- torque777
Re: Maxi life build
Well I gave mine an oil service today, used millers oils for the first time too, had lots of recommendations to use this oil so going to give it a whirl, going to go back to once a year servicing at 10k,
- torque777
Re: Maxi life build
Also today I fitted some replacement lower mirror caps with mk7 golf puddle lights, these had been modified allready by dizzy so saved me some money and time, I followed the how to guide but tbh it was simple enough, I have yet to code them as need to go see a mate with vcds, I did find that one of the two screws on each inner side of mirror snapped off when I tried to remove them, if I get chance I will drill them out and tap and helicoil them, the mirrors were very corroded inside, anyway they fit nice, can't wait to code now
Re: Maxi life build
What is the reason for moving to a annual/10k servicing plan?
What did you do before, less or more often?
- torque777
Re: Maxi life build
- torque777
Re: Maxi life build
Sorry I wrote a long reply and it's gone?
- torque777
Re: Maxi life build
Basically I was doing 5k oil changes with quantum longlife oil and I've moved to millers oils on advice from an engine builder and I'm going back to 10k oil changes
- torque777
Re: Maxi life build
All done and working but can't work out how to upload video with tapatalk lol
- Maxi4life
Re: Maxi life build
Loving the puddle lights, Is it an expensive mod to do?
- torque777
Re: Maxi life build
If you have to buy everything it's about £25 a light and £18 for looms, I bought mine from dizzee as he had allready converted his before
Re: Maxi life build
Epic build, just spent 2 hours reading this !
Re: Maxi life build
Ps. Apologies if I missed but how did you sort the dab Ariel issue?
- torque777
Re: Maxi life build
I've left it for now, I stay mainly local so can pick up most stuff, but I plan to fit a external dab arielDKX wrote:Ps. Apologies if I missed but how did you sort the dab Ariel issue?
