been looking but cant see any on ebayI.D.S. wrote:Chezzy saw them on ebay,think they were new.
Maxi life build
- chezzy71
Re: Maxi life build
viewtopic.php?f=13&t=10101
- zzeezzy
Re: Maxi life build
torque777
Just looking through ya pictures, them alloys look good,real good.
- torque777
Re: Maxi life build
Thanks ! I like them ...going to run with them for a while ..but have been thinking of going down to 18's just because they might be a bit less harsh and cheaper on tyres ...I'm down to 4mm on front budgets so will see what tyres I can get later on this year
- torque777
Re: Maxi life build
Washed her tonight and fitted my new cree reverse bulbs ...
Old
New
Be good in winter ..ran this type on mk5 golf for a year and that one is now doing service in our jetta so good service life
Old
New
- Ryan
Re: Maxi life build
Where did you get those bulbs from pal?
- dubvan
Re: Maxi life build
Daylight! Linky link, pretty please!
Jonesy
Jonesy
- torque777
Re: Maxi life build
I got them from a guy called tahir ...he is on other forums ..and on instagram ...imperial automotive lighting ...I paid £25 posted
- torque777
Re: Maxi life build
Tahir_asif786@hotmail.co.uk is his email
- torque777
Re: Maxi life build
Well spoke to chris wells at cc tuning in burton on trent today ...top guy who writes his own maps and maps for other tuners ...taking mine in next month and will get it data logged and have a session on the rollers to see what sort of map the previous owner had installed ....I'm sure I will end up getting it mapped again as at least I know then what map is on it and who has done it
- torque777
Re: Maxi life build
Decided to get dirty today and clean my scuttle out
It wasn't too bad but had quite a few leaves in there ..also took the nearside wheel arch liner out to clean out any crap that had built up in there
While that was out I tidied up the horn wiring ..I didn't solder the wires when I did my twin horns so put that right and used loom tape to cover
Then finished off with a hoover inside
- torque777
Re: Maxi life build
Decided to fit my air vent rings tonight
Really pleased with them ..think they lift the interior nicely ...took a bit to fit ..the you tube video shows you cleaning up the inside of the ring to fit ..but in the end I found it fit better if left sharp at the edge ...you do need to gently bend them to fit as the vent isn't a flat circle ...on another note I went to fit these
Got them off ebay ..I measured the center bore of wheel and it was 70mm so ordered 70mm but they clips are too tight and it kept snaping off the clips ..utter crap ..should of tried vw ones ..still need to replace caps but don't know what make my reps are ....
Also my mate took a photo of mine and his T5 camper at work today
Re: Maxi life build
He likes to park close
- torque777
Re: Maxi life build
Yes I did say that ...
- torque777
Re: Maxi life build
Ok so I've started to source chrome switches ..now I've bought Chinese one's before and ran them on a mk5 golf for a couple of years so know they work ok ...so I can find every switch apart from mirror switch unless I go genuine ..so thought I would try this ...
One Chinese golf mirror switch
Using plastic trim tools I popped the knob off
Did the same to my vw switch and fitted the knob ...one looking oem chrome switch for £7.99
Re: Maxi life build
That looks really smart and defiantly looks oem!!
Nice job on it,
Nice job on it,
