Maxi life build
- torque777
Re: Maxi life build
Thanks was really easy
- torque777
Re: Maxi life build
So tonight I changed my door switches ..my passengers door one had fallen apart ..
Removed switch holder and found even the holder was broken so I improvised and used a cable tie in a figure of eight around new switch and holder which did the job nicely
So moved onto the drivers door and used my trim tools to pop the handle off
All back together and working
- dubvan
Re: Maxi life build
The little touches you're doing are all adding up. Nice work and great piccies, bud.
Jonesy
Jonesy
- horace01
Re: Maxi life build
Hi,torque777 wrote:Forgot to say ..I'm using megs 105&205 with hexlogic pads ..but going to get a lake country pad to do the rest
Which LC pads did you end up using?
Be interested to know as we both have soft paint and I'm going to be giving mine a full paint correction soonish...
- torque777
Re: Maxi life build
I'm using an orange pad ..medium heavy cut ...I've used it so far on half the caddy and it does the job nicely ..then used a hex logic green polishing pad
- torque777
Re: Maxi life build
Another simple mod ...
Just finishes things off nicely
- Banditbarron
- Sales Caporegime
Re: Maxi life build
Have you got links to mirror switch and window ones? I assume window ones still gives one touch operation?
- torque777
Re: Maxi life build
Yes window ones work just as vw intended ...pleased with quality look of light switch ..I had a genuine one in my mk5 golf and tbh you can't tell any difference
- Banditbarron
- Sales Caporegime
- torque777
Re: Maxi life build
Ok can't seem to work out doink link on mobile so these are the ebay item numbers
181416192922 for mirror sw
321278972314 for light sw
171195922521 for window sw
- Banditbarron
- Sales Caporegime
Re: Maxi life build
Liking the nice little touches with the switches
- torque777
Re: Maxi life build
Thanks just makes it nicer to sit in ...need to get my suspension sorted really ..fed up of looking at box in garagemucca250 wrote:Liking the nice little touches with the switches
- torque777
Re: Maxi life build
Well some might of seen this on another post but had heater fan problems.. No 1.2.3 speeds but had 4 so fitted this
And cleaned the fan and lubricated the bearings
And so far all seems to be working
- torque777
Re: Maxi life build
So today is rolling road day...
Any guesses what figure she will get on the unknown map she is running??
