Stan-The-Man-With-The-Van build thread
Hi everyone,
I decided I might post up a build thread of my Caddy here instead continuing in new members section.
She is 1.6 TDI 75BHP in solid gray. I also have mk4 R32 so didn't really need powerful van as it wont carry super heavy loads either.
The factory extras include:
-Trendline pack (RCD310, BT, Rear parking sensors, Color coded bumpers, mirrors, handles, cruise control, pockets under the seats)
-Light and Vision packs (Bi-xenons, h/l washers,cornering lights, auto dimming rear view mirror, rain sensing wipers, auto lights)
-Carpet in cab
-Heated windscreen washer jets
-Climatronic
-Heated seats + upgraded fabric
-12V socket in rear
-First Aid kit and warning triangle under the drivers seat
-Passenger airbag
-Hill Hold
-Front fogs
+ I might be forgetting something
Was waiting for her about two months so this gave me a chance to gather up few additional extras I wanted to have. I pretty much stick with OEM mods/parts with my cars but If I see anything nice aftermarket I will have it too. Will try to post part numbers of what I used to keep everyone informed.
This is the car as I picked it up:
I will start with OEM door sill set: 2K0 071 310
I was worried about application but it was actually quit easy. Everything is included in the box: instructions, 4 x door strips, cleaning wipes, soapy solution. Just mix the solution with water in some spray bottle, wipe the sills with alcohol wipes provided, spray the sill with solution and line up the sill strip. Once the sill is lubricated it will move around so you shouldn't have trouble lining it up nicely. If you feel it starts to catch the sill and you didn't manage to line it up just keep spraying solution on it. Then with provided squeegee start squeezing out the solution from under the strip. While you do this you will notice it starts to stick nicely, keep running it gently and then I used microfiber cloth instead to keep squeezing excess suds out. Its handy to use someone to help too. Once we started next strip we always went back to check the previous one to make sure it didn't lift anywhere and gave it another wipe with the soft microfiber.
The result:
Stay tuned...
-Carpet in cab
-Climatronic
-12V socket in rear
-Passenger airbag
-Hill Hold
-Front fogs
The result:
Stay tuned...
Re: Stan-The-Man-With-The-Van build thread
What a lovely looking van, will follow this as you progress. How much was the sill protector strips.
Think i paid £40 for mine,only used the front ones. If your interested
They were around €40 here.Springer Mad wrote:What a lovely looking van, will follow this as you progress. How much was the sill protector strips.
Was working on LED license plate lights but unfortunately getting the bulb warning on dash
Back to the bat cave looking for resistors...
- torque777
Some great touches there
- chezzy71
one of my favorite colours on new caddys nice little bus
viewtopic.php?f=13&t=10101
- tocizbrloga
The color is great
Great colour my mates bought this kit for sills as well as the oem rear bumper one, top quality
Dubtech Custom Vans. Suppliers for - KW,ST,AP Suspension systems, Bilstein suspension, V-Maxx , Official RECARO dealer, GAZ Shocks, Cobra Seats, 07967 106 906 bigvw@hotmail.co.uk https://www.facebook.com/Dubtechcustomvans
Really nice spec you have got there, just ordered a couple of these for our company
- Drumbum
Such a nice spec! Enjoy it man
"Be excellent to each other. And party on, dudes." -- Bill & Ted
Thanks lads!!!
I really didnt expect the Caddy to be so nice van to drive.
To get rid of some of the road noise coming from the back through the bulkhead, I got this installed today.
Motexion solid bulkhead with window and with textile on cab side
Took the van for a spin and there is a big improvement
I had a small issue fitting it as the screw holes don't fully line up with original mounts, but this is easily sorted without any damage. It seems all or most Motexion bulkheads have similar issue as we fitted non textile version to my pals Caddy too and we had the same problem.
Also in my case I removed the roof in order to install it, so I would recommend to do so too if you planning on fitting one to a Caddy that has a roof lining in the rear. I didnt put it in back yet as Im in process of fitting some led lights to pimp up the rear a bit
To be continued...
To be continued...
Also Touran MFSW with grey stitching fitted
Have matching handbrake to come along too once when my Touran console with armrest goes in
Great progress in a short space of time, keep it up.
- caddyirl
Touran console brand new? Been on da hunt for one second hand and an engine cover in all the breakers around here no luck so far
