Page 39 of 46
Re: My caddy build and face lift
Posted: Sat Jun 09, 2018 2:21 pm
by KenTDI140
I’ve seen this done on the inlet ports before. Rosten performance do it and I think that’s where dark side get their heads done.
I got my big valves from Rosten.
The theory about this Finnish on the port walls is this.
Air traveling down a tube has friction slowing it down. This gives a dead zone of slower moving air along the tube walls and the center section moves at a faster speed.
When you have this golf ball effect it makes the dead zone run closer to the port walls leaving a larger fast moving area in the middle of the port so you flow more air.
Posted: Sat Jun 16, 2018 11:54 am
by KenTDI140
This morning I have pulled out my engine and gearbox. So now it’s time to crack on with converting it to 2.0 ltr.
I’m also going to make some other internal changes to the pistons to help with turbo spool and increase engine torque.
By the way if any one knows of anyone that might be interested I have a fully reconditioned BLS engine e here which has been converted to 2.0 ltr with the 150 crank and rods in it for sale. Also got a steel solid flywheel and clutch which is for a 6 speed box that won’t cause gearbox rattle.
Posted: Sat Jun 16, 2018 12:04 pm
by torque777
Hi Ken, I've just spread the word on your engine
Posted: Sat Jun 16, 2018 12:44 pm
by KenTDI140
Thanks m8. It’s one I built for a friend but he let me down on it so it stands me in quite a lot of money. It’s had a full engine ballence too
Posted: Mon Jun 25, 2018 6:37 am
by KenTDI140
Starting to rebuild everything now. Most of the panels have arrived from vw and I have got hold of another 2016 touran front bumper to remake the custom bumper I made last time.
I’m also cracking on with the engine mods now too
The block is all bored out to the maximum oversize for the .5mm oversize 2.0ltr pistons. And I have started working out the piston protrusion and clearances for the valves. I’m machining the pistons to remove the valve pockets as I have modified the brand new head to sink the valves back a little to make them flush with the head face.
Here are a couple of pics of the head so far with the porting mostly done
Posted: Mon Jun 25, 2018 7:15 am
by torque777
Great work, don't find many who can do this anymore
Posted: Mon Jun 25, 2018 8:17 am
by KenTDI140
Thanks torque.
It takes a lot of time and concentration as for the piston to head clearance I’m trying to work to a tolerance of 1 thou of an inch.
I’ve alway done my own head porting and gas flowing as when I was younger I worked for a company that was really into all the performance tuning and we had all the engine reconditioning equipment too.
Posted: Thu Jul 05, 2018 9:16 pm
by KenTDI140
That’s the pistons all machined now and ready for Balencing
I have almost finished the new cylinder head too and the block is now also ready to paint and build up.
I’ve spent hours skimming the block so that all the pistons protrude by exactly the same amount and working out the compression ratio
Posted: Thu Jul 05, 2018 9:40 pm
by james400
Love seeing this comeing together keep up the good work
Posted: Sat Jul 07, 2018 10:38 am
by KenTDI140
Started getting the body work rebuilt and the custom bumper under way today.
Posted: Sat Jul 07, 2018 10:44 am
by Caddyluv
Love it. Be like a new van soon.
Posted: Wed Jul 25, 2018 8:49 pm
by KenTDI140
Finnished building the bottom End today
Posted: Wed Jul 25, 2018 8:56 pm
by james400
KenTDI140 wrote:Finnished building the motto. End today
Cant wait till i get back and come pick mine up off you
Posted: Wed Jul 25, 2018 9:45 pm
by KenTDI140
Ahhh
Posted: Fri Aug 10, 2018 10:19 pm
by KenTDI140
I have now finnished the engine and am working on making a new inlet manifold to help improve flow I have used the premium from a 2.5 transporter a manifold from an old pre pd Deisel engine and the flange from a pd manifold.
Once it all finnished and I have tig welded it all together it will sweep up over the rocker cover and drop down the front of the engine.
I’m also going to use the anti shudder valve from the 2.5 as it’s butterfly valve is 10mm larger than the bls one.
