Page 13 of 36
Re: Brooneye's build
Posted: Tue Feb 06, 2018 2:51 pm
by brooneye
Look forward to seeing the updates.
Decided to try a different style on the rear, still trying to figure it all out
Posted: Tue Feb 06, 2018 7:35 pm
by james400
That front bumper im in love with lol well nice
Brooneye's build
Posted: Tue Feb 20, 2018 5:04 pm
by brooneye
Not got much done lately as been unbelievably busy with work, but tonight I did manage to fit the new speakers I bought a while ago.
I opted for the vibe slick series 2 as I have the vibe slick series already in.
New vs old
They sound a lot better compared to the old ones, just got to play around with them now.
Also managed to get the mfsw buttons working with the help of the control pro unit. I now have to find a new set of buttons for the volume side
Posted: Tue Feb 20, 2018 8:41 pm
by sausagefingers
Lovely van mate, one of my favourite transformations on here
Posted: Wed Feb 21, 2018 1:36 pm
by brooneye
Just scored what I think is a bargain. Paid £19 for some volume control buttons from a breakers, there was a set on eBay with the same missing trim bit for £80
Posted: Mon Mar 05, 2018 3:41 pm
by brooneye
Yesterday managed to do a few little jobs first up was to replace the damaged left hand mfsw buttons
Secondly changed my clocks over for the 2014 style. A massive thanks to Doc for taking the time sorting these out for me and I have to say they are a massive improvement. Also it’s great to have a finished dash after nearly a year as I thought it was pointless putting the painted trim back on only to have to keep removing it.
A quick question for people with these style clocks, is the oil light meant to flash on three separate occasions after starting?
Posted: Mon Mar 05, 2018 4:02 pm
by brooneye
Also managed to get a mot today and it sailed through
Posted: Mon Mar 05, 2018 4:48 pm
by Barbel330
What's the difference between your old and new clocks? Mine are like yours I think. Never noticed the oil light flash but I'll check next time I start it.
Posted: Mon Mar 05, 2018 4:59 pm
by Doc
Nice to see the instrument cluster finally fitted, brings the cabin up a few years with the more modern look over the old red display.
Which oil light have you got flashing? Is it on the centre display?
Have you checked with VCDS, no faults?
Posted: Mon Mar 05, 2018 5:29 pm
by brooneye
Barbel my original ones were the poverty spec lowline.
Doc thanks again for all your help. Been out of action for a while that’s why it’s took so long to get it switched over and it definitely looks much better.
It’s the oil light on the centre display. As I said it’ll flash a few times go off then flash like this a further two times and then stop. The oil temperature rises and I’ve checked the oil level.
Haven’t checked on VCDS, that’ll be me next job.
Posted: Mon Mar 05, 2018 8:41 pm
by btaylor2k
Great job mate, some great tips and ideas for my build
Posted: Fri Mar 09, 2018 1:07 pm
by brooneye
I’ve been today to see if there is any faults showing and after clearing a few the oil level sensor is still showing.
After speaking to the guy he seems to think it could be possible that the wire is damaged rather than the sensor.
He also thought it could possibly down to something as simple as a pin needing swapping around.
My question, More aimed in Docs direction, does a pin need swapping around and if so which one? I’ve tried searching but nothing is coming up.
Any help would be greatly appreciated
Posted: Fri Mar 09, 2018 1:16 pm
by Doc
I've never seen it where a pin needs swapped.
The fact the light goes out makes me think it is working and wired ok.
What was the exact fault in VCDS?
Posted: Fri Mar 09, 2018 1:25 pm
by brooneye
This is the print out, don’t know if it makes sense to you
Posted: Fri Mar 09, 2018 2:36 pm
by Doc
So it's the "Oil Level Thermal Sensor" fault that kept coming back?
