Battery Upgrade
Re: Battery Upgrade
The Varta E44 silver dynamic is the same battery as the Bosch S5008 and is slightly cheaper too. From what I have read elsewhere Varta makes the batteries for Bosch. So if you buy the Bosch S5008 battery just remember it is a Varta battery with the Bosch logo on and also a little bit dearer.
Re: Battery Upgrade
Thanks good to know.
I have done some research on battery drain so will connect my mult meter is series and see if any significant current is being drawn, will then pull fuses to identify the offending circuit.....
Caddy Maxi C20 Startline 1.6TDI 2015 Mk4 facelift
Ex BG
Ex BG
Re: Battery Upgrade
Hi guys anyone ever have a problem with battery drain I unplugged the radio and turned off all interior lights but still getting dead battery after about 3 days any ideas much appreciated TIA
- Bad666
Re: Battery Upgrade
Hi anyone know if the 096 Bosch fits in upgraded golf battery cover I’m just about to fit?
Re: Battery Upgrade
Yep, that'll fit no problem.
- Bad666
Re: Battery Upgrade
Cheers Doc
