Led DRL Resistor wiring help
Hi folks
Need to wire in resistors to my headlights loom as I'm getting the light on my dash board thinking iv got a blown bulb
I have the resistors not sure which wires inneed to splice into tho on my wiring harness
Van is a 2011 caddy 140 TDI with just one plug connector for the whole headlight
Re: Led DRL Resistor wiring help
The resistors sold for this function are a huge fire risk to your van, if I were you I'd have the bulb error coded out rather than fit something which might see you without a van some day.
- dizzee stuff
Doc is this possible on a early van ? I did have a look not that I know much about this but it looked like you needed a different tool for the Job VAS5054?
I think I have a tool that can sort that for you!
- dizzee stuff
Cheers Doc
What do I need guys to code it out please
I have the full genuine VAG COM btw
Nobody able to help ?
- dizzee stuff
The only info I could find was on google, it looked like after 2009 you could alter the binary coding to accept LED's ?
VAG CAN professional is the tool you need.
Vag come can only do the leds for the number plates
Cheers tho pal
What's vag can
Cheers tho pal
What's vag can
