gear selector strip?
- deanopolini
can someone please tell me how I can find the gear selector on my caddy and how to go about stripping it as my gears are stiff thanks
- dizzee stuff
Re: gear selector strip?
is it tight going across the gate of forward & back into gear?
- deanopolini
forward and backward m8 when its cold its worse, really bad getting into first and second but when its warm its a lot better
- dizzee stuff
You can remove the airbox disconnect the selector cables and check they are free by operating the gear lever, I would also check the gear box oil is clean & the level is correct. while you have the cables disconnected you can operate the selector by hand to make sure its not stiff, check the up & down movement (neutral) then the rotational movement (gear selection)
do the gears select ok with the engine not running
does the clutch movement feel normal
- deanopolini
So stripped selector down cleaned it up works smooth with engine off but when its on its notchy any ideas has plenty of gear oil ect
- dizzee stuff
If all gears select ok with engine off it would suggest you have a clutch problem
