Electric windows
Electric windows
Hi got mk3 2010 caddy 2.0 sdi looking at changing normal door windows to electric windows any ideas to change it over and what does it involve cheers col
Re: Electric windows
Hi, welcome to the forum.
Adding electric windows is quite straightforward so long as you stick to the simple rules of: 1. Source motors and door cards from the same car, 2. Add the correct wiring from the cabin fuse panel to the window motor via the a-pillar socket.
There is a how-to topic on the forum but you won't have access without building your post count a little.
How did you get on mate? I'm looking to buy an aftermarket kit myself
I'm gonna give this a go, got touran door cards and panels for my 2012 caddy
Fingers crossed
Fingers crossed
so i tried this today, got the panels on and all the wiring in then nothing would work and the doors wont lock now
i put the permanent live from the fuseboard and am totally goosed scratching my head i thought this would be straightforard but ive seen a post where you have to re pin the plug going from the A Pillar loom to the door so im gonna give that a go to see if it works
hopefully i will be able to look further into this once ive got enough posts on ere
I have complete doors from a 20 plate caddy, will this fit direct or does this need the wire from fuse box.
@Treevaldo
How did you get on with this I have a 13 plate caddy and parts from an 07 touran, it’s unclear if it will work or not, the latest I have seen is an 11 plate caddy which worked after repinning the loom.
