Front fog lamps
Rusty138
Front fog lamps
Post by Rusty138 » Sat May 11, 2019 6:37 am
Hi, I am new to this site and trying to up grade my 15 plate highline.
Does anyone know if it's possible to programme front fog lights to work as turn lights... what I mean is on newer vehicle When you turn steering wheel fog lamps light up and show the corner... suppose you could possibly call the cornering lights.
Anyway is it possible
tommyzooom
Re: Front fog lamps
Post by tommyzooom » Sat May 11, 2019 6:37 pm
I'm not sure on the 15+ models, but certainly on 04-15 vans, factory fitted fogs can be coded for cornering fogs with vcds..
dynamic duo
Re: Front fog lamps
Post by dynamic duo » Sun May 12, 2019 12:15 am
Hi Rusty138 , yes it is possible with VCDS, you need to go to Central Electrics and use the security code and then adaption.
I think the channels are LB45 and RB5 to enable the cornering lights.
cheers,
Luis
r1lea
Front fog lamps
Post by r1lea » Sun May 12, 2019 3:46 am
Yes it’s possible
Security access isn’t required
Off the top of my head it’s
byte 14
bit 7
Rusty138
Re: Front fog lamps
Post by Rusty138 » Sun May 12, 2019 9:30 am
Thanks boys for the heads up much appreciated.
