Hello everyone, just joined the forum. Currently have a 2011 caddy 1.6. & golf GTD. Really enjoying some of the posts. Some really good information about on here.
So am currently on with rear facelift lights. Can some clarify if they need coding or can I swap pin around to make them work. Had a look and seen links but because I am new it will not let me open them. Any available to help?
Newby
- DeanWhit
Re: Newby
Theres a 'how to' thread on here that you can use when you've acquired the access. You have to re pin the cables into the correct terminals, once complete you'll have a 'right side reverse light' error message on the MFD which you'll need to code out.
Re: Newby
Hello Dean, Thanks for confirming. I have seen the link but when i click on to it i get message saying i can not view this topic yet. can admin tell me how many post i need to view the thread?
- dan@biali
- Lister79
Re: Newby
Hi mate get a build thread started and you’ll soon rack up enough posts to request full access. In the mean time there is some info on the wiring changes in my build thread that will get them working, but you will need to have coding done to light up the lower bar and remove the build warning light.
Re: Newby
@lister79
Thank you so much mate! You are a life saver, loving the build thread. Thanks for the advice and will take up on starting a build thread
Apologies to admin I will take a look at introduction thread and get them posts out.
- Lister79
Re: Newby
No problem mate. I’ll look forward to seeing the build thread.
