Dog bone inserts on worn bushings.
Has anyone tried to use a a powerflex dog bone insert on a knackered lower engine mount bushing?
It looks like such a pig of a job that im trying to find ways out of doing it. If the pu one fills all the holes up and holds it solid it seems like it might not matter if the bushings a bit knackered... Any experience or thoughts?
Re: Dog bone inserts on worn bushings.
if its the dog bone mount in the subframe, VW have a special tool to replace it, less than an hours labour if I remember correctly. So I had a main dealer do it rather than mess about with inserts or anything.
If you specifically want the Polybush to make it stiffer, that's different. Someone hopefully can advise who has done it..
- Lister79
Do it right and replace the worn bush is the only suggestion I’d make. Also using the inserts on diesels causes unbearable vibrations. I installed one in mine when it was a 1.6TDi and it literally lasted a lap round the block before it was removed again.
Thanks for the replies. I don't like the idea of a lot of extra vibration. I was thinking to get the softest durometer. Which colour one did you go for?
I'll talk to vw and get quote but I imagine they'll sting me for parts to make up for any saving. Is there anywhere you can hire the tool? I've seen them for sale but can't find anywhere that hires them.
- Lister79
It was the yellow one.
Even if you can’t get the tool they are easily replaced by dropping the subframe. It’s false economy putting an insert in a worn bush, plus I promise you’ll regret it and end up removing and replacing the bush anyway.
I'll have a look for invoice but I think it was something like 120 or 140 total cost of parts and labour. I think the oem bush is two parts top and bottom and both totalled about 60 ish.. Hopefully not totally mis remembering. The actual dogleg is obvs an extra cost but you can change that diy dead easy
fyi was more like 190 parts and labour...
I’ve seen someone use the scissor jack to press the bush in.
It’s in two parts.
Instead of the ground, put the subframe under the scissor jack and start to jack up the van, the van won’t move until the bush has pressed in.
Or take the subframe with the bushings to a garage that has a press.
It’s in two parts.
- C Chis
I can also confirm polybushing the arm/engine mounts on a petrol engine (VR6) will give vibrations at low engine rpm when manoeuvring, fine the rest of the time.
The way to solve the worn bushing is to replace it with a new one.
yup
I agree with everyone above I fitted the powerflex insert to the dogbone bush. i did'nt even make it off the drive, the noise was terrible
I removed it straight away
I tried a red Powerflex bushing in my 1.6 TDI due to the mount being shot. Although it improved the gearchange/accelerator action no end, the whole van vibrated like a sewing machine at idle. Fine once up and going though. And VERY noisy! Made my 1990's Octavia TDI feel like a Rolls Royce (well, probably - I've never been in the latter).
I've compromised by removing the front half of the insert and leaving the rear half in. Very tolerable vibration and noise and a nice positive gearchange/accelerator action. Perhaps worth a try if you want a quick and cheap-ish "fix".
Thanks for all the reply's
I'm definetly not up for the extra rattling.
I spoke to vw to get a quote and they wouldn't give me a quote till I bring it in for inspection! I'd rather do it myself than waste my time hanging around at vw so I decided to buy the instalation tool and new bushes and I'll put the tool on ebay afterwards. Maybe do the bushes on my passat too as a precaution whilst I have the tool
yea that's bullshit, its a fixed price replacement part (so I was told by VW). So has a fixed book time for labour, like cambelt or clutch. If you can do yourself, I'd say go for it. I expect you will be able to sell the tool to get most of your money back, for the next person that needs it
Yea I think the mechanic was just being awkward on purpose. Maybe he'd had a bad day
Hopefully the tool works well, it looks like it should make it super easy.
I bought the tool and swapped it for a febi bushing. Easy job with the tool.
Imits for sale now if anyone is interested.
