The radio unit in this van is a RCD310.
The sloth build
Re: The sloth build
- Mrsloth
Re: The sloth build
Seems the steering calibration worked
- Beaker2135
Re: The sloth build
Nice one, simple solution.
- Mrsloth
Re: The sloth build
Discovered the issue with the passenger speaker!
Next task.
Next task.
- Mrsloth
Re: The sloth build
I much prefer the lines with rails, not oem but still works as intended.
- Mrsloth
Re: The sloth build
I had bought the optisound kit and not checked if I had the tweeters standard. I know you can buy the kit with the modded loom included but can you get this separately or instructions to do it yourself?
Re: The sloth build
It's very simple to spur off the door pillar socket to pickup the audio wires for the tweeters. No need to run all the way back to the radio unit and add a bunch of unnecessary wires behind it.
- Mrsloth
Re: The sloth build
Cheers Doc. I’ll give that a try instead then
