Front speaker
Front speaker
Have got a blown door speaker may look at getting tweeters as well anyone share where they got theirs from cheers
1.6tdi waiting for it to go bang for a tfsi lump
GTi seats, 19s 255/35/19
Coilovers, egr blank, stage 1 map
Purple
Purple
Re: Front speaker
Vibe optisound. Comes with a complete kit to either upgrade, or with loom to add tweeters (if your van never had them). Mostly plug and play.
If you know your way around an install, you can buy the Vibe slick 6c component speakers. source the bits yourself and it it works out a little cheaper.
lots of threads with general instructions, and vide on YouTube. I bought the 6c speakers and did it all myself. I think I posted in 'what did you do to your van' with details.
Massive upgrade and sounds excellent off factory headunit.
Re: Front speaker
I got a Audison APK165p set from Amazon a few years back, sound is fantastic but I'm not into loud music. They can go to 240w max so an amplifier is an option if you feel it necessary.
Re: Front speaker
I fitted ESX QXE-32 speakers on the spot where the tweaters are supposed to be it was a mess getting those in lots of modification of the plastic and airduct underneath and with my 2-din radio i used the signal forr the speakers in the rear(later switched cabels by moddifing the iso harness so these are now front and the door is rear) but if you go for one with less depth its probably easyer to install and then you can have extra speakers instead of just a tweeter probably the Alpine SXE-0825s will fit
- Dav02
Re: Front speaker
Check out Crown Custom Audio. I bought my door speakers and tweeters from here.
https://www.crowncustomscaraudio.co.uk/ ... k4-caddy-1
Not sure which kit I got now, but the site seems to have more options now.
Re: Front speaker
Thankyou for all the replys will be looking about now
Purple
Purple
Re: Front speaker
I don’t have the caddy at the minute but looking to order speakers to minimise downtime once it’s returned. Is 2018 highline swb van likely to have dash tweeters from factory? I have the CarPlay discover media setup
Caddy MK4 highline. Scirocco heated leather with electric lumbar & full elec drivers seat. ESP/ ASC button & coded. TPMS button & coded (ABS version). Carpet & insulation rear & Touran front carpet. Custom bulkhead. Tints. Front splitter. Side bars. 197hp map (on rolling road). Bi-xenons. Wireless charger. Laser grill led lights. Ambient lighting. Coilovers. Colour coded bump strips. Reverse camera. Front & rear sensors
Re: Front speaker
I ordered the ones for tweeters in the end & turns out mine had factory wiring & tweeters. Upgraded the speakers but spare harness. Oh well
- Daniel0402
Re: Front speaker
I’m running some BLAM 8inch speakers in mine with the tweeters, If I was to do again though would go for the 6.5 in door and a dedicated subBgd99 wrote: what did you end up getting? looking at getting some new ones for mine
Re: Front speaker
Only had my van 2 weeks, noticed straight away there was no bass from drivers side, not investigated further as just expecting the speaker to be blown so ordered a pair of Focal ICVW165 units from fleabay, hopefully will be a big improvement.
- dontknowz
Re: Front speaker
Ive also got mine from here comes with everything you need , audsion prima set with tweeters is really good comes with the quad lock harness adapter so its all plug and playDav02 wrote:Check out Crown Custom Audio. I bought my door speakers and tweeters from here.
Re: Front speaker
I used crown too. All nice & easy
Re: Front speaker
I got the plug play kit from scr distribution- phoenix golds. Awesome upgrade
- Ambrose2KN
Re: Front speaker
Theres so many choices really and considering its in a van cab then any majors differences in quality will be negligable.. you can get adequate replacements for 30-40£ but myself am just going staright in with Focal Speakers as they are renowned to be up with the highest quality drivers made. However if its power and loudness you are after then id suggest looking at Pioneer.
1.9TDi 104bhp BLS, Ex-BG LWB Cargo.
