Time to start a new build. Ex BG maxi. Hereford.
- Nicklouse
Re: Time to start a new build. Ex BG maxi. Hereford.
Decided to fit the Winter wheels from my old T4.
Ready for any snow.
Ready for any snow.
- Nicklouse
Just need to drill a few holes too keep them in place when as a seat or a load platform/bed
Yes there is one more board.
- Nicklouse
“Finished” it off just need to do the back rest catches but that needs the work tops is.
Front part is stored in the back.
Or the whole can be stored in the garage.
- Nicklouse
Just spent the afternoon recessing the speakers as they were sticking out too much and causing problems.
- Nicklouse
Just waiting for the better weather.
- Nicklouse
Goodies arrived today.
2009-2015 VW GOLF MK6 CABRIOLET WIPER INDICATOR CRUISE CONTROL STALK 1K5953507T
And some I have had for a while. Waiting for a dry weekend.
- Nicklouse
May dash now has new lights and tells me different info.
Cruise control fitted and coded and working and tested.
Looking nice. I remember you and your short nosed velle from back in the day when I was active on the T4 Forum.
- Nicklouse
Your caddy looks like a great buy. Yep 3 countries on and I still have a blue/black VW with Gurt big spots on it.
Hi Niklouse !
I have a question about your rear spoiler . What kind of fixture will you use ?
Do want to drill wholes for some screws in the back doors or do you stick it with maybe tiger seal ?
Or an other solution ?
Greets Ultrakurz
Greets Ultrakurz
- Nicklouse
No idea as yet.
- Nicklouse
Power “wall” is in.
Just one 240v socket and an outlet to the charger.
Everything else is 12v
Redoing the LEDs as the low cost ones were crap.
- Nicklouse
MOT passed. Now let’s get everything else sorted. Opps belts getting done on the 19th.
- Nicklouse
Belts done. Something I won’t skimp on.
Have been following other peoples post on cost which has been interesting.
Some of the prices people have been putting out there must not have included things like the water pump etc.
Anyway both belts changed. Water pump and coolant. Had the oil and filter changed at the same time.
Labour 4.5hours. Total cost £720 a bit more than I expected.
More working out what/how to do what I want on the inside.
Found that the “gaskets” that came with the rear door spoilers were actually both for the small door version.
OPPs.
Well they are on. Bolted. Will add some sealant as well.
Saw another just down the road. Currently seeing different ones every weekend.
OPPs.
- Nicklouse
Hinges changed. The whistle has gone.
Only changed the door leaf of the upper hinge.
The whole just was made fun with the previous owner running speaker cable through the connector rather than re pinning it.
