Page 3 of 8
Re: Maxi - Not a Show Van
Posted: Tue Aug 08, 2023 11:12 am
by the swan fiend
You’ve just missed the show at Tatton Park. It’s a good one! It’ll be on this time next year so keep a look out on the forum as we have a club stand. There’ll be others in the meantime I’m sure though.
Posted: Sun Aug 13, 2023 6:38 pm
by Be4ny13
Finally had a day off with lovely weather to give the caddy a good clean after a couple weeks of rain. Thoroughly washed the outside and gave the front end a clay bar and polish, something I've been meaning to do for ages. First time clay barring a vehicle and it's definitely the most satisfying thing I've ever done, been going outside just to look at the clouds in my bonnet
Posted: Sun Sep 17, 2023 9:47 am
by Be4ny13
Posted: Sun Sep 17, 2023 1:48 pm
by kazzi
Love the look of that faux suede, got me tempted
Posted: Sun Sep 17, 2023 4:17 pm
by Be4ny13
kazzi wrote:Love the look of that faux suede, got me tempted
Be warned, once you start it spreads quickly
Posted: Sun Sep 17, 2023 4:18 pm
by Be4ny13
As the seats were out to make the job easier they got the suede treatment too
Posted: Sun Sep 17, 2023 5:18 pm
by Lister79
Looking good, coming together nicely
Posted: Sun Sep 17, 2023 5:38 pm
by Be4ny13
Lister79 wrote:Looking good, coming together nicely
Thank you, can't say yours hasn't inspired me somewhat
Posted: Mon Sep 18, 2023 9:44 pm
by Gmancan1
Your cup holders came out fantastic!! I had this very same idea have the plastics upstairs
Did u line the cupholder screw up ? Or is it just floating there?
Posted: Mon Sep 18, 2023 10:10 pm
by Be4ny13
Cheers! They're held by the one screw you can see underneath and a rail it clips into on one side
Posted: Mon Sep 18, 2023 11:15 pm
by Gmancan1
Was thinking that or else make wee bracket or somethibg
It looks fantastic tho. Anything you would change? If done again?
Posted: Wed Oct 18, 2023 10:53 am
by Be4ny13
Covered the end caps of the rear seats in suede to tie them into the front of the cabin and added a little Amazon cargo net to the rear door to hold my gloves now the weather's turned colder
Posted: Sat Oct 21, 2023 2:39 pm
by Lyfie
Interior looks amazing
Posted: Wed Nov 15, 2023 1:11 pm
by Be4ny13
After the heavy rain and storms we've been having I finished work to find a puddle in the back of my van. The dreaded roof bar leakage! Not big enough to cause any issues but enough that it soaked into the rear head lining and distorted it. Off the bars came to reseal around all the holes and took the opportunity with them out the way to clay bar and ceramic coat the roof. Bars now back on and water right I turned to the head lining. The plan is to install 6 spot lights, 4 in the load area and 2 above the rear passengers, running on a 3 way switch to work with the doors opening and closing and on/off as and when I want them, and a separate dimmer to operate each side. So far I've got the shape cut out, load lights installed and mostly wired up, need a cut out for the switches and then to test them all (the masking tape is temporary). The passenger spot lights will be on a separate circuit, I'll update this thread when I do those. Once this is all mounted and working correctly I'll be covering the other side in the same black faux suede I've used in the front to give the interior some continuity
Posted: Wed Nov 15, 2023 7:33 pm
by GregWalters
Loving all the suede interior! Will definitely be doing that to mine
Let me know details on wiring the interior lights to come on with the doors and a manual switch, would be interested in copying also!
Lovely van on the inside and out
