Steering wheel upgrade
- adeybroth
I’ve got this to replace the rubbish PU wheel on my mk3. Trying to source the correct airbag, think the wheel is from a polo and airbag needs part 6C0 880 201C?
Can anyone confirm the correct airbag part no?
Re: Steering wheel upgrade
Ive just ordered one off ebay for mine hope its the right one its item number 36436075408 take a look pal it was only £40 plus postage
cheers
Craig
cheers
Craig
- adeybroth
Nothing comes up when I put that in, everything I’ve seen that looks like the one for my wheel is 150 quid
Remind me tomorrow as have an airbag out that I can check the part number off. I’m at that unit tomorrow afternoon. Word of warning, once you fit the wheel, drive it to make sure it’s straight before you fit the airbag. The airbag in that type of wheel is an absolute pig to get back out again. Spent literally 2 hours wrestling with it Sunday night compared to any other airbag I’ve removed (inc the golf mk8 one) which has taken minutes. You have to alight both side springs from behind whilst wiggling. As it’s so tight one side clips back as you push the other forward. Having struggled with this, I would 100% rather have some codes to deal with & clear than get th bag back out again. I’ve not driven without airbag so hopefully someone else can confirm my logic but assume once connected back up, it’s just a case of resetting the code with vcds or odis
Caddy MK4 highline. Scirocco heated leather with electric lumbar & full elec drivers seat. ESP/ ASC button & coded. TPMS button & coded (ABS version). Carpet & insulation rear & Touran front carpet. Custom bulkhead. Tints. Front splitter. Side bars. 197hp map (on rolling road). Bi-xenons. Wireless charger. Laser grill led lights. Ambient lighting. Coilovers. Colour coded bump strips. Reverse camera. Front & rear sensors
sorry bud bit of a technofobe here must of put the wrong number in ive copied the link off ebay here for you
https://www.ebay.co.uk/itm/364636075408
hope that works
Craig
hope that works
Craig
- adeybroth
Cheers Craig- that’s the same as the one I’m taking out unfortunately.
- adeybroth
@kryton85 Cheers really appreciate if you could check the part no for me, that would be really helpful.
Adey.
Adey.
- adeybroth
Craig,
This is the wheel and airbag together,
https://www.ebay.co.uk/itm/355274577203 ... media=COPY
airbags a different shape, but need to be careful there seem to be a couple of airbags they look very similar.
If you have ordered the wrong airbag, you should be able to return it.
Nice one adey yes i think ive bought the wrong one Ill just return it and ask for the correct one if they have one in stock,
cheers bud
cheers bud
sorry forgot to select 'notify me'. i now have my old airbag in front of me. its 2k5 880 201 m 81u 06s (think its just the first bit you need). clock spring / squab that is from that car is 5k0 953 569 bc
- adeybroth
Cheers bud, that’s really helpful. Also do you know the torque setting and spline size is for the wheel? I need to get myself a set of splines.
Don't buy a cheap set of XZN Bits, they are a false economy.
Something decent about £20+
This one seems OK (the great Famex set I have is no longer available)
https://www.amazon.co.uk/LEXIVON-Triple ... B07M6884DY
@petrev just what I need to help with the seat removal
Caddy Highline 1.4 TSI
Sorry - Cancel this
They don't ship to UK
Tha Famex set is available, but only from Belgium ! At a price.
https://www.amazon.com.be/-/en/Famex-10 ... B004ZR7QME
Not sure if you will ever need the Odd-size bits that only come in this set !?
Great quality set though.
