Problem after Touran dash swap
RyanCummins
Post by RyanCummins »
I have completed a Touran dash swap in my 12 plate 1.6 caddy. Since swap it keeps blowing fuses for the Obd reader. I have fittted a radio at the same time as well used the Touran heater controls ( I have cables but I am not bother about that at moment) any ideas what would be causing the fuse to blow straight away? Thanks
Re: Problem after Touran dash swap
Try disconnecting the radio and heater control, see if the fuse works with those out of the way.
RyanCummins
Thanks Doc
